Adding Link to Post?
/ Adding Link to Post? #1
Rusty
Hampton Township, Bay County, Michigan
Kubota B7500HSD-R
Help - How do I add a link to a previous post into a post or in a reply to a post? Thanks, in advance! /forums/images/graemlins/confused.gif Rusty
/ Adding Link to Post? #2
Go to the link you want to reference. I prefer to open another instance of my browser so my posting page stays in place. Highlight the URL/Address and hit <Ctrl>C.
Go back to your post and hit the markup option "URL" (located below the posting dialog box.) At the first prompt box hit <Ctrl>V, which enters the address. In the next prompt box, enter the title of the link you want to reference. If you're previewing posts, you can check your link to make sure it worked.
/ Adding Link to Post? #3
Just to clarify:
Ctrl-C = COPY
Ctrl-V = PASTE
You can also use your right mouse button to open a menu to copy/paste or the Edit menu in the browser window as well. (Note: You must have something highlighted before the CUT/COPY options get enabled)
/ Adding Link to Post? #6
Glad we were able to help.
Test 2 can create a problem on TBN. It will make page not rap around to next line if the address is longer than a normal page width.
/ Adding Link to Post? #7
Rusty, one more thing to learn about posting URLs...My standard 'Long URL' message follows.
MikePA: Cleaned up long URL. Please review your message before posting it. It's simple not to do this. Just insert a descriptive word or two between the {url=http://whatever}<font color="red">Enter words here</font>{/url} instead of the entire URL. Replace parentheses with brackets in previous example.
/ Adding Link to Post? #9
</font><font color="blue" class="small">( Rusty, one more thing to learn about posting URLs...My standard 'Long URL' message follows.
MikePA: Cleaned up long URL. Please review your message before posting it. It's simple not to do this. Just insert a descriptive word or two between the {url=http://whatever}<font color="red">Enter words here</font>{/url} instead of the entire URL. Replace parentheses with brackets in previous example. )</font>
Test
{url=http://www.tractorbynet.com/forums/showflat.php/Cat/0/Board/support/Number/658477/page/1/view/collapsed/sb/5/o//fpart/1}test{/url}
/ Adding Link to Post? #10
What am I doing wrong Mike?
test
I see it is the the lower case bracket and not the upper case as in your response.
/ Adding Link to Post? #11
You forgot to change the parentheses {} to brackets. /forums/images/graemlins/smile.gif Refer to the last sentence in my example.
25057SFL (A64557)
25057SFL (A64557)
2018 JOHN DEERE 350G LC EXCAVATOR (A65053)
2018 JOHN DEERE...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
2007 Sterling L9500 Tri-Axle Dump Truck (A66736)
2007 Sterling...
2025 SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A66734)
2025 SZYMJ...
2003 Johnson 60 hp 4-stroke Outboard Boat Motor (A66738)
2003 Johnson 60 hp...
