Adding lights to ROPS
   / Adding lights to ROPS #31
Bob,
The link should take you to what I used. They seem to fairly strong to me but they have to be flat on your roll bar to be good. My roll bar on the outer edges is rolled some and there the magnets don't hold to well. Yes trees and branches would knock them off. But I put them under my roll bar so they won't get hit so easy and I like the flexibility of being able to set them back wards really fast.
Grounding Magnets
Just take the bolts out and place your lights in place. Will need washers, enouh to get the bolt under flush for magnet to sit full.
murph
Murph,
Thanks. I had done a Harbor search for "magnetic ground", but this item did not come up. I'm going to order three right now.
Bob
   / Adding lights to ROPS #33
Hope it works out ok for you. They are kind of expensive so maybe you just want to try one and see if they hold strong enough for you. Harbor Freight does have a return policy I believe if you don't like them.
murph
1840 (A51248)
1840 (A51248)
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
1977 Ford F-100 Ext. Cab Pickup Truck (A53422)
1977 Ford F-100...
2017 Makita HM1307CB 35lb Demolition Hammer (A55973)
2017 Makita...
48in Pallet Fork and Frame Skid Steer Attachment (A55851)
48in Pallet Fork...
2018 MGB 2500HP QUINTUPLEX FRAC PUMP (A55745)
2018 MGB 2500HP...
