Adding hydraulic for backhoe Massey 1755
   / Adding hydraulic for backhoe Massey 1755 #1
Range rider
Massey Ferguson 1755
I was going to take off the power that control grapple through a w r long switch. So it would go PB to w r long switch and take the P from switch back to backhoe PB input and then from backhoe P back to P input on tractor will I have any issues thanks
   / Adding hydraulic for backhoe Massey 1755 #2
I am not sure I understand fully your plan. With the WR kit you would simply plumb the solenoid valve using the power in line for the backhoe then go from the solenoid valve back to the power in of the backhoe. No other changes have to be made. Good luck.
   / Adding hydraulic for backhoe Massey 1755 #3
Put the backhoe valves after the loader and grapple valve. Many BH valve stacks can not handle full system pressure. If you have the grapple after the BH and use the grapple you could damage the BH valves.
The pb runs to the wr long valve for grapple out the wr long valve to the backhoe then back to t when backhoe is hooked on when. When backhoe is unhooked jumper is in place the backhoe input is connected to a line back to p easy to say hard to explain
   / Adding hydraulic for backhoe Massey 1755 #5
Sounds correct to me.
2022 JOHN DEERE 331G LOT NUMBER 99 (A53084)
2022 JOHN DEERE...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
1997 International 9300 Day Cab Tractor (A52384)
1997 International...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53472)
Michelin CARGOXBIB...
2014 INTERNATIONAL LF687 SLEEPER (A52576)
2014 INTERNATIONAL...
