Adding hydraulic for backhoe Massey 1755
   / Adding hydraulic for backhoe Massey 1755 #1
Range rider
Massey Ferguson 1755
I was going to take off the power that control grapple through a w r long switch. So it would go PB to w r long switch and take the P from switch back to backhoe PB input and then from backhoe P back to P input on tractor will I have any issues thanks
   / Adding hydraulic for backhoe Massey 1755 #2
I am not sure I understand fully your plan. With the WR kit you would simply plumb the solenoid valve using the power in line for the backhoe then go from the solenoid valve back to the power in of the backhoe. No other changes have to be made. Good luck.
   / Adding hydraulic for backhoe Massey 1755 #3
Put the backhoe valves after the loader and grapple valve. Many BH valve stacks can not handle full system pressure. If you have the grapple after the BH and use the grapple you could damage the BH valves.
The pb runs to the wr long valve for grapple out the wr long valve to the backhoe then back to t when backhoe is hooked on when. When backhoe is unhooked jumper is in place the backhoe input is connected to a line back to p easy to say hard to explain
   / Adding hydraulic for backhoe Massey 1755 #5
Sounds correct to me.
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2021 MACDON C3812 LOT NUMBER 34 (A53084)
2021 MACDON C3812...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A53472)
2017 Ford F550...
