Adding Hydraulic Fluid - 2007 Montana 5740C
   / Adding Hydraulic Fluid - 2007 Montana 5740C #1
SteveMo
New Brunswick, Canada
2006 Montana 5740C
Hi, All:
I just removed a blown hydraulic hose and should add back what was removed from the hose, so, I am asking:
1) What type of fluid to use (is it 80W90)?
2) Where to add the fluid? Is it one of the top bolts on top of the transfer case? I see a dipstick there but no idea what that reservoir is? Does the drivetrain share the same fluid?
Sorry for the newbie questions. The only manual I could find in the past for this tractor is in Chinese!
Thanks!
   / Adding Hydraulic Fluid - 2007 Montana 5740C #2
Hi, All:
Thanks!
You want tractor combination transmission/hydraulic fluid. Get it at any farm or tractor store.
Auto stores don't have it.
Do NOT use 80/90, power steering fluid, straight hydraulic fluid,or engine motor oil. Tractor combo hyd/transmission fluid is about 20wt and is special....and costs more.
There has to be a fill point somewhere close to that dipstick, or use a funnel and pour it in there.
luck,
rScotty
   / Adding Hydraulic Fluid - 2007 Montana 5740C #3
the hydraulic fluid fill point is located on the right rear of tractor in-between the three point hitch (it is the dip stick /hole)...the hydraulics and the transmission share the same fill point
2163 (A58376)
2163 (A58376)
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
Sterling T/A Ox Bodies 16Yd Dump Truck (A56858)
Sterling T/A Ox...
2020 MACK P164T (A58214)
2020 MACK P164T...
SHOPMADE MANIFOLD TRAILER (A58216)
SHOPMADE MANIFOLD...
2015 FREIGHTLINER CORONADO 122 SD (A58214)
2015 FREIGHTLINER...
