Adding Hydraulic Fluid - 2007 Montana 5740C
   / Adding Hydraulic Fluid - 2007 Montana 5740C #1
SteveMo
New Brunswick, Canada
2006 Montana 5740C
Hi, All:
I just removed a blown hydraulic hose and should add back what was removed from the hose, so, I am asking:
1) What type of fluid to use (is it 80W90)?
2) Where to add the fluid? Is it one of the top bolts on top of the transfer case? I see a dipstick there but no idea what that reservoir is? Does the drivetrain share the same fluid?
Sorry for the newbie questions. The only manual I could find in the past for this tractor is in Chinese!
Thanks!
   / Adding Hydraulic Fluid - 2007 Montana 5740C #2
Hi, All:
Thanks!
You want tractor combination transmission/hydraulic fluid. Get it at any farm or tractor store.
Auto stores don't have it.
Do NOT use 80/90, power steering fluid, straight hydraulic fluid,or engine motor oil. Tractor combo hyd/transmission fluid is about 20wt and is special....and costs more.
There has to be a fill point somewhere close to that dipstick, or use a funnel and pour it in there.
luck,
rScotty
   / Adding Hydraulic Fluid - 2007 Montana 5740C #3
the hydraulic fluid fill point is located on the right rear of tractor in-between the three point hitch (it is the dip stick /hole)...the hydraulics and the transmission share the same fill point
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
Magnum 4000 Series Hot Water Pressure Washer (A55272)
Magnum 4000 Series...
20 UTILITY TRAILER (A58216)
20 UTILITY TRAILER...
