Rear Blade Adding hydraulic angle to rear blade
   / Adding hydraulic angle to rear blade #32
im always amazed at the time and energy people put into projects considering the starting products and finish products....
   / Adding hydraulic angle to rear blade #33
That works great Tom. I think you'll really enjoy having that much control over how your blade attacks dirt and snow.
Thanks guys.
That was the first video I have ever posted.
took a few minutes to figure out how.
My son is more impressed with the video post than he is with the blade.
I'm always making projects and showing the kids how things work...
I guess it's a little boring to them, but a video post on You Tube
Wow dad!:confused3:
Maybe the old man is Hip
   / Adding hydraulic angle to rear blade #35
Nice work and thanks for the ideas!
   / Adding hydraulic angle to rear blade #36
Tom nice work!
Is there any way to put in an Auto center feature for the blade in the future? Asking because I would like to do something similar with the Kubota
Thanks.
I don't know if it would be simple or inexpesive to do so.
When angled you would want it to hold the angled position. A log splitter valve has detent return but will not allow a position control in two directions.
Maybe two logsplitter valves and flow shuttles?
But
Something/Pressure has to signal it has reached center position and cause the control to release.
I build and service pneumatic/electric automated equipment at work and I know I could whip up a control device using a combination of the two quickly but I am not as familiar with what is available in hydraulic controls.
At work I would use limit switches or proximity sensors and could deactivate 12 volt hydraulic solenoids.
Bit of a tough one without involving electronics I think.
Just starting to work with hydraulics on this tractor.
Far left or right would be easy enough, but center is a different story.
A proximity switch can be mounted on the cylinder and it could sense when the piston is at the center position.
You need electronics to use the proximity switch?
Tom
   / Adding hydraulic angle to rear blade #38
unless you are doing millimeter jobs... just stick/paint 2 lines and when they match.. you are in the center! ;)
   / Adding hydraulic angle to rear blade #40
Tom nice work!
I'm pretty sure it could be done like Tom said, but it would be more complicated than anything I'd want to tackle. I don't think the microswitches would stand up to the use my blade gets moving ice and snow. Hydraulic (pressure) switching would be the more robust way to do it, but I don't know if that's possible.
Nice job, Tom! Looks like an OEM product, which is supposed to be a compliment.. the cycle time is fairly quick, but not too fast either. Nice balance between speed and precision. You used a 3" cylinder, right? I think your hydraulic flow must be somewhere close to my Kubota, the cylinder movement speed is about the same or slightly quicker.
Sean
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
MULCHER (A58214)
MULCHER (A58214)
2025 Safety Basket Forklift Attachment (A59228)
2025 Safety Basket...
2007 Yamaha Rhino 660 (A56436)
2007 Yamaha Rhino...
Drago Olimac 6R Corn Head (A59814)
Drago Olimac 6R...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
