Adding Guages To your Yanmar
   / Adding Guages To your Yanmar #111
Sears/Craftsman had Big settlement to make about the HP rating of thier engines. Not long ago. I ran into it on the Net. when i started shopping for a small compact tractor.
   / Adding Guages To your Yanmar #112
Hmm, that's interesting. I would have expected it to be quite a bit higher than that, though the outside of the block must not get as hot as the coolant it carries. Does anyone know at what temperature the sensor is specified to turn on the warning lamp?
QUOTE]
SORRY! I meant to say 235 F. I believe that is the temperature the temperature warning light is supposed to kick on.
   / Adding Guages To your Yanmar #113
I have a 2210BD that has a factory temp gauge included in the dash panel although I have never seen any real movement on the gauge. I did some testing with the sending unit and it looked like the gauge was questionable. I decided to add some additional gauges instead of trying to repair the original. I also decided to use an electrical temp gauge instead of one with the mechanical sensor so I could use the existing wiring and not worry about the copper tube.
I ordered a universal 2 gauge and 3 gauge pod from glowshiftdirect.com since I wasn't sure which would fit my dash better. The 3 gauge was a better fit so I did some contour sanding for a nice fit on top of my current dash. Glowshift had the pods in stock and they were delivered quickly, I would do business with them again FWIW.
I used Equus temperature, voltage and oil pressure gauges from O'Reilly Auto Parts since they were convenient and in stock. I tied onto the existing wiring connectors in the dash and used the original temp sending unit wire to the motor. The sending unit that came with the temp gauge fit in the original sending unit hole with one of the supplied adaptors and I made up a pigtail with a couple crimp-on connectors to hook onto the original wire. I had already added a tee into the oil pressure sending unit so I just had to run the plastic tubing from the gauge to my tee. I had run the plastic tubing for oil pressure on my old tractor with no problems so we'll see how this holds up.
I haven't had a chance to work it hard yet to see what type of water temp and oil pressure it develops under load.
Steve
https://picasaweb.google.com/105265...hkey=Gv1sRgCLzZntuQsLbHYg#5780664622254894066
https://picasaweb.google.com/105265...hkey=Gv1sRgCLzZntuQsLbHYg#5780664635735711970
https://picasaweb.google.com/105265...hkey=Gv1sRgCLzZntuQsLbHYg#5780664640970567954
   / Adding Guages To your Yanmar #114
Since much of the stuff mentioned earlier in this thread is not available these days. What is the go to now for these gauges?
   / Adding Guages To your Yanmar #115
Since much of the stuff mentioned is not available these days. What is the go to now for these gauges?
The one here is the best I've seen and has an original look,
Click on the Sunpro link under the image, it is still sold on Amazon.
   / Adding Guages To your Yanmar #117
I had forgotten that more gauges was a major theme in this Yanmar forum back when I first started reading here. In fact I bought a gauge but never got around to installing it. Don't remember if it was Temp (likely) or Oil Pressure. At any rate I eventually gave the gauge away.
I am now of the opinion that Yanmar got it right with all of their design choices on these old classics. It's worthwhile to verify that the dash lights function properly. But that's all the attention needed. Just do a thoughtful warmup before running the engine hard.
The temp light seems to have been designed as simply a boilover warning, with different spec senders between the thermosiphon and pumped cooling systems. And anything short of boilover considered an acceptable operating temperature. Diesels are more efficient at higher temperatures. There's not even a thermostat in YM2000. They didn't overlook it, they designed a system where the warning light is all that is needed. Simplicity as a feature, as proud evidence of careful design, not simplicity as a cost savings.
It's obviously important to keep the cooling system up to spec, with the proper coolant and radiator cap, and the radiator rodded out or replaced if it doesn't cool properly. Yanmar expected thoughtful maintenance.
Some of these engines ran a lifetime of high output in semitrailer refrigeration units where nobody climbs up there between suggested maintenance intervals. Small offshore fishing boats, similar, where the owner literally owes his life to diesel engine reliability.
Now 40 +years later the fact that most of these tractors we own have only needed appearance reconditioning suggests that Yanmar got everything right, so long ago.
   / Adding Guages To your Yanmar #118
I considered changing the Temp. Sensor to Gauge. In the summer I've had the Temp. light come on a few times over the Yrs.. Last time it happened and Been a few Yrs. I drained and flushed the Radiator. I also dropped the Antifreeze ratio to 20%. It's in the 90's now and I haven't tripped it yet so I'm believe in good shape. Again!
   / Adding Guages To your Yanmar #119
Brand M Parts in Midland, Texas, sells a temperature gauge kit for the YM Series Yanmar tractors.
   / Adding Guages To your Yanmar #120
But for the other Amazon posting, you get all 3 gauges. (y)
1969 Lincoln Continental Mark III Sedan (A56859)
1969 Lincoln...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
*Selling at Royal Auction Zephyrhills, FL Location* (A59230)
*Selling at Royal...
2016 John Deere 825I (A57149)
2016 John Deere...
SKID STEER MOUNTING PLATE (A58376)
SKID STEER...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56436)
2023 Kubota...
