Adding Dozer Blade to my JD2210
   / Adding Dozer Blade to my JD2210 #1
tacbat
Ohio
JD2210
I have a dozer blade 54" from the trusty jd314 that I am going to modify a bracket to fit the 2210. My question is if the hydro oil that is in the lift cylinder compatible with the hydro oil in the new 2210? I am wondering if I need to flush cylinder/s with fuild from 2210 and then top-off fuild? I was told by the sales guy that it is not a problem but he is a saleman not a tech. I would also like suggestions on how to flush the cylinder.
   / Adding Dozer Blade to my JD2210 #2
The hydro oil should be the same but....
In some older JD hydros, it was ok to use type F auto transmission fluid in place of the regular hydro fluid. Now they pretty much specify to use the low viscosity hydro fluid.
Flushing the cylinders might not be a bad idea. Not only because of the possibility of different fluid, but mostly because of dirt. In an older implement like your blade that has been taken on and off a lot in the past, could probably have some dirty fluid in it.
I don't think a "flush" is needed, but I'm sure it wouldn't hurt to at least drain the fluid from the cylinders and hoses. Then clean the fittings up putting it back together. I would just unhook the hoses and push/pull the cylinders to get out what fluid you can. Then when you attach it to you tractor, cycle the controls to fill the cylinders/hoses. Then bring your hydro level on the tractor back up to where it should be.
   / Adding Dozer Blade to my JD2210 #3
Yep, thats just how I did it when I retrofitted an old JD blade to fit my JD 650. I drained out the old (red) fluid by pushing the cylinders in and then out.
Bobcat T590 (A53317)
KUBOTA M8540D TRACTOR (A60430)
KUBOTA M8540D...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
WOLVERINE TQH-26-02C, 3 PT RECEIVER HITCH (A60430)
WOLVERINE...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
2013 HAM 289I-30 8 WHEEL PNEUMATIC ROLLER (A60429)
2013 HAM 289I-30 8...
