Adding AM/FM tractor radio
   / Adding AM/FM tractor radio #11
Builder
I would go with the Chrysler style in Cowboy's 2nd pic (the radio in the middle). They mount with two screws on the corners and work pretty well. I bet a trip to the local bone yard would have you set up for about $20 and you would be able to cut out a good chunk of the wiring harness to take with you. I just pitched two of them (sorry) but I would definitely go that route vs the older traditional units that mount via the tuning and volume posts.
You can find the typical wiring guides for the radios here:
http://www.installdr.com/Harnesses/DCP-Wiring.pdf
Thanks, but I think it's too big. I'll have to measure the opening, but it looks like today's typical small slender opening for a radio.
I have a line on an AM/FM/CD from a guy I do a little work for here & there.
If it falls through, I may get back to Cowboy357 for one of the smaller units.
UNUSED WOLVERINE TQH-26-01C 3 PT QUICK HITCH (A57193)
UNUSED WOLVERINE...
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
Deere 524K (A53317)
Deere 524K (A53317)
Hose Reel (A55787)
Hose Reel (A55787)
