Adding a sprayer inductor tank and clean water rinse tank
   / Adding a sprayer inductor tank and clean water rinse tank #1
Dadnatron
Versailles, KY
JD 5100e with FEL
I purchased a 240 gal 3pt hitch sprayer and have it up and running.
I'd like to add an inductor tank as well as a clean water rinse tank.
The tank opening on my sprayer is NOT in a readily accessible location, at least not without a bit of work. I have room along the side and I'd like to add an inductor if it is a reasonable thing to do. I see several inductors for sale, but having no experience, I have no idea of what makes a good/bad tank? What do you recommend? What do you recommend I avoid? What do you wish you had vs think is a waste?
I'd also like to add on a separate 'rinse water' tank, probably about 35gal should be enough. Anyone added one and any recommendations on what to do vs avoid doing? Any recommendations on a brand/model? I suspect I will just have to build one from scratch.
   / Adding a sprayer inductor tank and clean water rinse tank #2
How much spraying do you do?
Put the inductor on a premix tank and load the sprayer, "Hot".
Someone can mix a batch while you are spraying or you can mix multiple batches at once.
Rinse tank is nice but how much more weight can you hang on the 3pt?
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
American G-Model Pump Jack (A56438)
American G-Model...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
1969 Lincoln Continental Mark III (A56859)
1969 Lincoln...
Toro Mower (A56857)
Toro Mower (A56857)
2021 John Deere 333G (A55272)
2021 John Deere...
