Dadnatron
Veteran Member
I purchased a 240 gal 3pt hitch sprayer and have it up and running.
I'd like to add an inductor tank as well as a clean water rinse tank.
The tank opening on my sprayer is NOT in a readily accessible location, at least not without a bit of work. I have room along the side and I'd like to add an inductor if it is a reasonable thing to do. I see several inductors for sale, but having no experience, I have no idea of what makes a good/bad tank? What do you recommend? What do you recommend I avoid? What do you wish you had vs think is a waste?
I'd also like to add on a separate 'rinse water' tank, probably about 35gal should be enough. Anyone added one and any recommendations on what to do vs avoid doing? Any recommendations on a brand/model? I suspect I will just have to build one from scratch.
