Adding a Loader to a 2240
/ Adding a Loader to a 2240 #21
The front mount bolts have to be long enough to go through the loader frame, tractor side frame, front axle mount AND have a nut on the inside. I'd say 5/8 x 4" if SAE bolts. I do not recall if my 245 loader has SAE or Metric bolts at the front, it's been on over 20 years.
/ Adding a Loader to a 2240 #22
Are they 16 mm or will 3/4" work?
/ Adding a Loader to a 2240 #23
3/4" is real close to 19mm
/ Adding a Loader to a 2240 #24
16MM or 0.625 IN or 5/8'' is correct diameter mounting bracket frt bolts for 245 loader
/ Adding a Loader to a 2240 #25
I looked at mine (on the 2030) and the heads are marked 10.9, so they are metric.
Skid Steer Rotary Mulcher (A65640)
Skid Steer Rotary...
Komatsu D65EX Dozer (A66285)
Komatsu D65EX...
Hay Feeder (A66408)
Hay Feeder (A66408)
(12) 4.5"x9' Steel Posts (A66408)
(12) 4.5"x9' Steel...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
John Deere 5000-Series Tractor Grill Guard (A65640)
John Deere...
