Adding a Loader to a 2240
/ Adding a Loader to a 2240 #1
mtDanE
JD 2240, JD 1010u JD1010r, JD 420 l&g, JD 110 l&g
Good afternoon all,
I just picked up a 14six loader for my 2240. It came without the valve. I think I have settled on a prince 3 spool valve with a joystick (2) and 1 for a grapple or angle blade. the Boom also has a float. the valve has a max of 2five gpm. I will get the close center plug for it also. the tractor is rated around 9gpm It sound like this might be a little over board, so I wondering what others might do for a valve before i make the purchase.
also I need to know how to tap into the hydraulic system. it has 1 remote but I would prefer to leave it for other applications. There are 3 lines coming from the pump. 1 appears to be for the steering and brakes(?), the second one looks like it goes to the remote although it looks like it is plumbed into a large cast iron block before it goes there. the 3rd i assume it is the feed to the pump. this is all on the right hand side of the tractor under the floor board. My thought is I can T into the line before it goes into the remote. most likely where it transition from a hard line to a hose. I'm not sure where return should go.
Any help/insight would be appreciated.
Dan...
/ Adding a Loader to a 2240 #2
Dan, the 146 loader is a good match for the 2240. The pressure line is T'ed into the line feeding your remote. the factory setup used a "T" behind the cast block #6 and replace the steel line going to the remote with a hose #4. The return should be routed to the hydraulic filter cover. If your cover does not have a "port" to connect the hose, you should buy one. Returning the oil here assures that all the return oil from the loader gets sent directly back to the main pum so it does not starve for oil. Returning the oil directly to sump will cause the pump to cavitate and you will have jerky operation. The valve you mentioned should be fine as long as you install the closed center plug. Even the factory valve was rated for alot more flow. That is not a problem. An under rated valve would be a problem.
/ Adding a Loader to a 2240 #3
If you're careful you can reattach the original steel line that supplies the SCV to the lower fitting at pressure control valve. BTDT several times back when 2240's were new.
/ Adding a Loader to a 2240 #4
TX Jim is correct you can fit a Tee betwween the pressure control valve and the steel line for the rear valve. Did it when I put the 245 loader on my 2030.
jd110 is also correct, you want to return to the trans filter cover. You do not need as many fittings shown. The Tee with a cap is to allow other returns to the filter cover. My two rear SCVs have a hose from the end cover down to the trans filter cover, so I had a ported cover and only had to buy that Tee. I think I might have an extra ported cover(loader came with one too).
My 2030 has two rear SCV couplers, so I use one set when I use my grapple.
When I bought the 245 loader it came with the independent valve and joystick, cable operated.
Good luck on the install
jd110,
Thanks for the schematic, I was looking for that one to get me going. It appears that my filter cover does have the port, at least there is a large nut ~1 1/2" in size on the side of the filter. I will have to look at it again tonight to make sure it is the correct cover.
TX Jim and ZebraFive,
my 2240 already has the soft line exiting the pressure control valve to remote SCV. so I should have some play there.
Most likely i will get the fittings from Deere, only because I'm having a hard time getting my head around the different types.
I'm sure I will have some more questions.
Thanks. Dan...
/ Adding a Loader to a 2240 #6
Some of the later model SCV kits had a hose to replace steel line. Here's a list of the fittings & o-rings you should need to attach loader hyd's to tractor.
R39249 CONNECTOR,SPECIAL ADD 7.15 USD
F3171R PACKING, O-RING ADD 1.90 USD
R36075 CONNECTOR,SPECIAL ADD 10.99 USD
AW16707 UNION FITTING, UNION FITTING ADD 34.39 USD
R26448 PACKING, -O- RING ADD 1.22 USD
R26375 PACKING, -O- RING ADD 1.54 USD
/ Adding a Loader to a 2240 #7
Sounds like you lucked out on two counts. A hose to the SCV will make that connection easier and I'll bet that a ported filter cover is close to $200 now.
I was happy my 2030 had one.
Don't worry about the whole 10 gallons of trans/hydraulic fluid draining out when you pull the plug from your filter cover. You will ony get what oil it holds.
/ Adding a Loader to a 2240 #8
Zebrafive
Your guess was close to correct.
T31170 COVER ADD 171.60 USD
/ Adding a Loader to a 2240 #9
Zebrafive
Wow! Ouch! Not sure if it somethnig a bung could be welded onto or not. At least he does not have to worry about it.
Any idea why my SCVs have a return to this cover? Only one I've seen that way. Could it be because it has a Hi-Lo trans?
/ Adding a Loader to a 2240 #10
JD came out with the option to return SCV oil to the filter to aid in operating such things as orbit motors similar to the ones used on augers and post hole diggers. SELECTIVE CONTROL VALVE OIL FILTER RETURN KIT
/ Adding a Loader to a 2240 #11
I drilled and tapped a 1/2 inch NPT into the filter cover on my 4020, and put on a 90 deg elbow fitting. I put a JIC adapter on the end so I can take the filter cover off easier.
/ Adding a Loader to a 2240 #12
That's exactly what mine has, just never knew why. Thanks! :thumbsup: :)
Hey all,
I had put this project on the back burner until after sugering season was over. Well the neighbor came over and asked when I was going to get off my lazy butt and get the loader installed. I told him I was busy with making syrup and I still need to order a valve. He went to his truck and pulled out a JD joystick valve with the mount. He did not want anything for, he said he was going to throw it out.
For once out pays to procrastinate. off to get some houses and fittings.
Dane.
/ Adding a Loader to a 2240 #14
Hey all,
Dane.
Dang... you didn't even have to fall into the cooler vat of syrup to come out smellin' sweeter than well.... a stack of hotcakes! :D
Good neighbor, too.. If he don't tap trees - maybe he'll have fresh maple syrup anyway!
AKfish
Absolutely, he will new getting some.
It took 2 trips to the hardware store to get all of the houses and fittings, yesterday. I was still short by one house for the bucket and more oil. But the loader is out of the back of my truck and on the tractor. I had troubles getting the fitting out of the "flow control valve?", so I left it, put an adapter on and moved forward.
I found water in the filter housing when I removed the plug, so I drained all the oil out and replaced it.
This morning I now have a descent leak on the load control arm for the 3 point hitch. I will hold off adding three rest of the oil until I replace the o rings.
Dane.
/ Adding a Loader to a 2240 #17
To replace L/D seals and inspect the L/D shaft for wear one must drain trans oil.
/ Adding a Loader to a 2240 #18
I got a John Deere 245 loader for my 2240, the bolts for mounting the front side of the mounts are calling for M16X100mm bolts, the mount bolts onto the tractor mounts, what is with the 100mm bolts. I need to get bolts but I am figuring 50 or 60mm bolts, anybody have any idea.
/ Adding a Loader to a 2240 #19
I got a JD 245 loader for my 2240, what size bolts do I need for the front mount. The parts site are telling me I need 16X100mm, but doesn't it mount into the block. So what bolts do I need.
PALLET OF MEC 8000 PUMP AND V8 ENGINE BLOCK (A67714)
PALLET OF MEC 8000...
New/Unused Electric Winch (A65583)
New/Unused...
Lincoln Shield-Arc SAM-300 (A64912)
Lincoln Shield-Arc...
30" Canal Pump (A64912)
30" Canal Pump...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
80 Gal Fuel Tank (A64912)
80 Gal Fuel Tank...
