Adding a lean-to
/ Adding a lean-to
One more
/ Adding a lean-to
If your not tired of it now, here is the last one. The little shed needs to be moved. That was a goat barn that I made a few years back. It is on skids & the object was to drag it to different places that the goats would be keeping the weeds trimmed. Didn't happen & the goats have long been history. Especially after they got loose & trimmed everything but the weeds. /forums/images/graemlins/tongue.gif
/ Adding a lean-to #43
That really looks nice. It gives me some motivation, because my barn will be gambrel-roofed with a shed roof on one side, like yours. I'm even leaning towards the red color. I like your barn a lot!
One thing that I took notice of was how nice it looks with the metal siding. I was leaning towards hardi-plank on sheathing because I realy didn't like the look of the metal-sided buiildings I've seen. But, you've done such a nice job with the trim, etc., it really looks like a traditional wood-sided barn. With the cost of sheathing gone so high, you've given me something to think about. Did you insulate/finish the inside? If you get a chance, could you take a snap or two of what it looks like inside?
I'm not building a pole barn; mine will be stick-built on a monolithic slab with engineered trusses on 24" centers, one of the reasons being that it was easier to get engineered to the required 110 MPH wind load around here.
/ Adding a lean-to #44
Good job.
Question: How did you handle the flashing up against the originonal building. The fact that the buidling siding is not flat makes this complicated to get a good seal?
Fred
/ Adding a lean-to
As you can see in one of the pictures the flashing is pre-bent to a 120 deg. angle. It fits up in the building siding 5 inches. On the roof side there is a foam piece that fits the profile of the steel sheets. It goes down first then the flashing which is supposed to prevent any water from going back.
/ Adding a lean-to #46
molerjr:
sure looks nice finished the way you did it. sure could be a pitcure for some calander that those city goers would buy for a few dollars!
I think the little goat shed looks just fine there personally.
Mark M /forums/images/graemlins/smile.gif
/ Adding a lean-to #47
Can I ask how you attached the upper header to the exsisting building?
Nice pics, looks like you did a great job.
--->Paul
/ Adding a lean-to
Paul, thanks. The place where the board is attached is the same location as 2nd story floor joist. I just used alot 20d nails.
I took some pictures of the inside the other day, but it was pretty overcast & they didn't come out too good. I'll try again. As for insulation, I used 1" or 1 1/2" insulation board. I cut & fit it in between the 2X4's that go from pole to pole. Covered everything with OSB. I have an oil furnace. It would be better if I insulated the ceiling but I haven't gotten around to that yet. Plus I have stuff hanging up there & insulation would take up that space. I don't keep heat in it all the time just when I am working out there or like last year when I had a big Fiesta bowl party. When it is real cold, below 20 or so, I use the torpedo heater to get it heated fast then let the oil furnace takeover. I also have two water hydrants. One over a single laundry tub. I keep the hydrant open & put a valve on the end to regulate the flow. I just have to remember to close the hydrant & open the valve when it drops below freezing. (Yeah, I forgot a few times)
