Adding a 3rd function valve to NH Workmaster 55
/ Adding a 3rd function valve to NH Workmaster 55 #1
PumpingPete
Fort Scott, KS
New Holland Workmaster 55
Ok, officially tired of the hoses running to the rear of my tractor. I see there are kits that you can buy, and I have read the posts on here, but would like more specific information for my tractor. Please help.
/ Adding a 3rd function valve to NH Workmaster 55 #2
Hydraulics:
Type: open center fixed displacement
Valves: 1 or 2
Pump flow: 11.6 gpm [43.9 lpm]
Total flow: 16.9 gpm [64.0 lpm]
Steering flow: 5.3 gpm [20.1 lpm]
Where do you want to put the 3rd function, and what do you want to control?
I have a grapple that I want to control. I would also eventually like to buy a hydraulic post-hole digger.
/ Adding a 3rd function valve to NH Workmaster 55 #4
You have a 11.6 GPM attachment flow using an open center hyd system..
Is your hyd pump external and what do you have for hyd now?
Are the supply lines metal of hose?
Ok, I am a real newbie when it comes to this stuff, so not sure on the external pump question. I am running the grapple controls off of my single rear remote. The rear remotes supply lines are metal.
/ Adding a 3rd function valve to NH Workmaster 55 #6
Do you have a loader since you say you have a grapple ran off the rear hyd.
If you do have a loader and a two spool valve, then you can use a diverter/selector valve to switch between the loader curl circuit and the grapple.
12 VDC 13.2 GPM SAE 8 DOUBLE SELECTOR VALVE
You also need a switch, cable, and handle.
/ Adding a 3rd function valve to NH Workmaster 55 #7
And hoses to plumb it in. :thumbsup:
/ Adding a 3rd function valve to NH Workmaster 55 #8
External pump means just that, the pump is on the outside of the engine, and an internal pump is built in and may not have any lines on the outside of the tractor, making it difficult to add things.
If you can get to the flow path, you can modify the hyd flow path.
/ Adding a 3rd function valve to NH Workmaster 55 #10
That valve will work as you want.
However, that valve will provide full flow at all times unless you reduce the engine rpm, add a needle valve or a restrictor washer in one of the fittings.
How would you control the speed of the auger/grapple?
If the 3rd function valve is second valve in the series path, and the first valve is using all the hyd flow, the 3rd valve will have no fluid flow.
That is an expensive 3rd function valve.
You can gather up all the parts and do it yourself for less.
Thanks for all of the info J_J. Much appreciated. Any idea on where to find instructions/how-to on installing the valve you recommended?
/ Adding a 3rd function valve to NH Workmaster 55 #12
/ Adding a 3rd function valve to NH Workmaster 55 #13
I am looking to install a grapple on my existing bucket & found this thread searching 3rd function. Thanks for the links for the 3-part installation, it's even my exact tractor.
I'm not as well versed in hydraulics as I would like, but near as I could tell the kit in the video use this solenoid valve: D03S-2B-12D-35 - 12 Volt DC
Is the configuration correct? The rest of the kit looks like a few bracket, the knob/switch & some hoses. Am I missing something?
Thanks, TD
/ Adding a 3rd function valve to NH Workmaster 55 #15
JJ, Thanks for your reply.
I knew I needed the open center but didn't pay close enough attention to the actual valve schematic.
Will work on a parts list in the meantime but will most likely fabricate my own switch set-up for the loader control lever.
Thanks, TD
/ Adding a 3rd function valve to NH Workmaster 55 #16
You might even consider a two pole switch that will lock the grapple on in one position, and momentary position for momentary use.
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
Welcome to the Ranch Metal Decorative Sign (A64557)
Welcome to the...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
Unused 2022 Hustler Lift Max LE110 SS Bale Forks and Frame Tractor Loader Attachment (A66734)
Unused 2022...
