Adding a 3rd function valve to NH Workmaster 55
/ Adding a 3rd function valve to NH Workmaster 55
Thanks for all of the info J_J. Much appreciated. Any idea on where to find instructions/how-to on installing the valve you recommended?
/ Adding a 3rd function valve to NH Workmaster 55 #12
/ Adding a 3rd function valve to NH Workmaster 55 #13
I am looking to install a grapple on my existing bucket & found this thread searching 3rd function. Thanks for the links for the 3-part installation, it's even my exact tractor.
I'm not as well versed in hydraulics as I would like, but near as I could tell the kit in the video use this solenoid valve: D03S-2B-12D-35 - 12 Volt DC
Is the configuration correct? The rest of the kit looks like a few bracket, the knob/switch & some hoses. Am I missing something?
Thanks, TD
/ Adding a 3rd function valve to NH Workmaster 55 #15
JJ, Thanks for your reply.
I knew I needed the open center but didn't pay close enough attention to the actual valve schematic.
Will work on a parts list in the meantime but will most likely fabricate my own switch set-up for the loader control lever.
Thanks, TD
/ Adding a 3rd function valve to NH Workmaster 55 #16
You might even consider a two pole switch that will lock the grapple on in one position, and momentary position for momentary use.
2008 Ford Fusion SE Sedan (A59231)
2008 Ford Fusion...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
2021 JOHN DEERE 204L WHEEL LOADER (A62129)
2021 JOHN DEERE...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
