Added ToolBox
/ Added ToolBox #1
Mrwurm
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
Well, I got my new Digital camera and chronicled my latest project. I accidently had the camera set to 'close-up' mode so the pictures did'nt come out quite right. But, here they are anyway.
Step 1. Here's the "before" picture.
/ Added ToolBox
I am attaching to the seat belt mounts just above the rockshaft arms and in front of the SMV. The toolbox brackets will go on first and then the seat belt brackets will go on top.
/ Added ToolBox
Here is the steel attached with the first bend. I replaced the original grade 8 seat bolt bolts with longer grade 8 bolts so that I would maintain the the same amount of thread interface.
/ Added ToolBox
Second bend. This is 3/16 stock that I hammer bent in the vice. (cold)
/ Added ToolBox
Test fit of box to locate holes.
I slid the seat all the way back and put weight on the spring to make sure that I allowed enough clearance so the seat would not hit the box.
/ Added ToolBox
Finished project with proposed new location for SMV.
/w3tcompact/icons/hmm.gif Something not quite right.
/ Added ToolBox
Ah yes, there it is. /w3tcompact/icons/smile.gif
Now it's the right color /w3tcompact/icons/laugh.gif
/ Added ToolBox #8
Yes the toolbox is the right color. But the rest of the picture apears to be a Martion (spelling) landscape.
/ Added ToolBox #9
Say Jerry,
I thought you were going to "relocate" your turn signals up on the ROPS? With the SMV sign at it's new location, how you gonna do that?? /w3tcompact/icons/hmm.gif
Oh, I know! You're only going to be making right turns, so you only need the right side signal! Got it! /w3tcompact/icons/wink.gif/w3tcompact/icons/laugh.gif
/ Added ToolBox
Maybe I'll have to install dual blinking SMV's /w3tcompact/icons/clever.gif
Now, where to put that cupholder... /w3tcompact/icons/eyes.gif
/ Added ToolBox #12
Now everything's the correct color!
/ Added ToolBox #13
Cupholder? You mean yours didn't come with one? I thought they all did /w3tcompact/icons/grin.gif. Nice job on the install.
/ Added ToolBox #14
Jerry, You might want to move your SMV sign to the back of the seat. Just buy the sticker and put it right on the seat back. Attached is a photo of the one I put on my B2710. I always have it and its never in the way!
/ Added ToolBox #15
Great idea of the stick on SMV, mine came off when the bolts vibrated loose while mowing, rough cut mower sure does a number on them.
/ Added ToolBox #16
Great idea on the SMV, I have scratched mine up several times.
I will pick one up Monday Morning.
Glad to see someone using the KISS principal,
"Keep it simple stupid" it works every time.
Jim
/ Added ToolBox
Great idea ! I'll check it out for fit /w3tcompact/icons/smile.gif
/ Added ToolBox
OK GaryM /w3tcompact/icons/hmm.gif, what software did you use to fix it up ?
I use IrfanView and I have to swap all 3 colors.
/ Added ToolBox #19
I used photoshop 7.
Used the eyedropper to choose the color of the fender, set the brush to color mode and painted over the toolbox.
The color mode of the brush changes the color with out affecting the detail.
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63689)
2012 Ford F-150...
VERSATECH 66" GRAPPLE RAKE (A64277)
VERSATECH 66"...
Western 8.5 Pro Plus Ultra Mount (A62679)
Western 8.5 Pro...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2009 IC Corporation School Bus, VIN # 4DRBUAAN19B694286 (A65563)
2009 IC...
Multipurpose Skid Steer Mount Backing Plate  (A62679)
Multipurpose Skid...
