Add remote valve to L2900
   / Add remote valve to L2900 #1
scokeing
Eads, TN
Kubota L2900 GST
A newbie here with a question about hydraulics. Done a lot of searches on the subject here but want to be sure.
I have an L2900 GST with a front loader. I now have a pull gang reel mower with one hyd line that I need to add a remote connector and valve to the tractor. I priced the kit from Kubota and wow $800. Being a DIYer I think I can add this for less and have some fun doing it.
My oper manual shows the Hyd block outlet has 3 ports: (1) From implement, Inlet (2) To implement, Outlet (3) From Implement, Tank Port. All are commected to operate the Front loader.
I have read about the power beyond option and do not understand what it does in the system, just that it is required for this type of add to the system.
I have searched this site for help but still need help. If anyone could help with a flow diagram schmetic and explain how to "tap" into my current hyd system to add a valve and remotes.
Thanks to this site I have learned a lot about the mounting of valves and running lines along with the safety issues associated with hydraulics, that in itself is fantastic.
Thanks Scott
   / Add remote valve to L2900 #2
You haven't searched well enough. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
To add your own valve it must have power beyond capabilities, usually by just adding a sleeve into an outlet port.
To connect, you do as follows: <ul type="square"> [*]Disconnect the hose that is connected to the "from implement" port on the hydraulic block. This is the PB hose from the loader valve. [*]Take that hose and connect it to your aux valve's inlet port using a union fitting and another hose or just get a longer hose to go from the loader's PB outlet to your aux valve's inlet. [*]Run a hose from the PB outlet of your aux valve to the "from implement" port on the hydraulic block. [*]Finally, disconnect the hose from the hydraulic block "From implement tank port" and replace it with a Tee fitting. Reconnect the hose to one leg of the tee fitting and connect a hose from your aux valve's tank port to the other leg of the Tee fitting. [/list] You have just successfully connected your aux valve in series with the hydraulic circuit and are now all set to go.
434669 (A48836)
434669 (A48836)
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2014 Doyle Dry...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
1274 (A50490)
1274 (A50490)
1993 Ford Ranger STX Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
