A newbie here with a question about hydraulics. Done a lot of searches on the subject here but want to be sure.
I have an L2900 GST with a front loader. I now have a pull gang reel mower with one hyd line that I need to add a remote connector and valve to the tractor. I priced the kit from Kubota and wow $800. Being a DIYer I think I can add this for less and have some fun doing it.
My oper manual shows the Hyd block outlet has 3 ports: (1) From implement, Inlet (2) To implement, Outlet (3) From Implement, Tank Port. All are commected to operate the Front loader.
I have read about the power beyond option and do not understand what it does in the system, just that it is required for this type of add to the system.
I have searched this site for help but still need help. If anyone could help with a flow diagram schmetic and explain how to "tap" into my current hyd system to add a valve and remotes.
Thanks to this site I have learned a lot about the mounting of valves and running lines along with the safety issues associated with hydraulics, that in itself is fantastic.
Thanks Scott
Thanks Scott
