add power angling to landscape rake
   / add power angling to landscape rake #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
Landpride or Woods rakes are very expensive, like $1,200 for an 8 footer. Add the factory power angling option and it goes up to ~$1,800 !!
I can get a 8' Leinbach for $4-500. Seems like adding an angling cylinder wouldn't be that tough. Anyone try this?
   / add power angling to landscape rake #2
I haven't done it but was thinking about doing an angle cylinder for my rear blade, some one posted a pic don't know what forum/thread but you can get an idea from this pic.
If I do it I would want it to work with blade both forwards and with blade turned around should only require a couple of extra pins. I guess if I do it to the blade the same cylinder could be used on my rake, they're both 6'.
   / add power angling to landscape rake #3
There have been a couple threads on adding a cylinder to a rake or rear blade.
You're right, it's not that difficult to do. Some I've seen have a cylinder mounted not only for angling the rake, but also for turning the rake around. They do that by mounting that cylinder so that when pushed out all the way and then pulled back in, the blade or rake spins completely around. Larry G made his like that. There are a lot of photos and neat ideas in his thread.
Of course he made his entire rake from scratch!!!
Landscape Rake Build
   / add power angling to landscape rake #4
On my rake, a heavy duty 8' Ford rake I got over 20 years ago, I can set it up for power angle and also power offset. If any one is interested I'll post some pictures.
Andy
Nice article!! I don't have the time to adopt such a heady project. I was thinking more along the lines of taking a manual rake and adding a power angling cylinder.
   / add power angling to landscape rake #7
This is a Finn power landscape rake. The original mount angles the unit 15 degrees to the right. It is a solid mount with no adjustments. My plan is to alter the base, make it swival in both directions with the aid of a hydraulic cylinder. If I find a compatible pin and sleeve about 10" long I have the steel in stock to make the base.
I wonder what engineer came up with the fixed position idea ?
   / add power angling to landscape rake #8
Yeah, I know. That was one heck of build.
I just linked that thread to show it can be done. Didn't mean that you had to build your own rake. I've got a rake and am thinking of doing the same as you to mine.
I thought of a hybrid idea. Buy a cheaper Leinbach rake and add a Landpride power angling kit. The LP p/a kit costs ~ $400. However, it's unknown if their kit would fit a different brand of rake.
   / add power angling to landscape rake #10
Be careful with those cheaper rakes. That Challenger will pretzel a cheaper one. I had bought one of those $500 rakes, lasted just a few times before it looked like a churro.:( Remade the rake part with new channel and 4x7x1/2 tubing, now I need to work on the 3pt mount and add hydraulic angle.
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
RoGator RG1100C (A52748)
RoGator RG1100C...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
CATERPILLAR D6R XL CRAWLER DOZER (A51406)
CATERPILLAR D6R XL...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
