Anyone have any tips or tricks for adding the lights to the roll bar of a GC2610? Wondering if there are any good points to pull power from. Any suggestions on lights to look at?
Do a search of old posts and you'll come up with more solutions than you can handle.
A quick one that comes to mind is two clamp/bolts ( the type they sell to mount a spare tire to a trailer). A piece of 3/16" to 1/4" aluminum (easy to work and doesn't rust".
On the GC2600 there is a 4mm power receptacle at the back of the tractor to the left of the upper stabilizer link coming from the wire loom so suspect the 2610 will have one there as well. An audio speaker banana plug fits the plug nicely. The wire is 18 gauge so should easily handle a 15 amp draw.
