Oil & Fuel Add Engine Oil
   / Add Engine Oil
Midniteoyl - thank for your response, that is not the oil fill below the oil filter. I looked at that, the oil filter has to be removed just to remove the cap on that thing. Still not sure what it is but seems like some sort of pressure regulator.
K5lwq - thanks for your reponse, I saw that but thought that was attached to the fuel injection system. If it isn't then that's great, now I know where to add the oil. However are you sure that is it? I don't want to add oil in the wrong place and mess up the injectors or something.
   / Add Engine Oil #12
That is it.
   / Add Engine Oil
Thanks, I appreciate all the help.
2002 Ford E-350 10ft. Box Truck (A55852)
2002 Ford E-350...
2014 Freightliner M2 106 Ambulance (A55852)
2014 Freightliner...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
