Add Aux hydraulics to Branson 3510 h
   / Add Aux hydraulics to Branson 3510 h #1
sandybeach
Whidbey Island,WA
Branson 3510H
What will it require to add a hydraulic line (pressure and return). I want to get a 3-point hydraulic log splitter.
Where are the locations for installing lines to the rear of the tractor? Will I be able to use "standard" metric plumbing?
   / Add Aux hydraulics to Branson 3510 h #2
If you have a loader, pull the fluid from the power beyond of the loader valve.
   / Add Aux hydraulics to Branson 3510 h #3
Is your tractor open center or closed center hyd?
What attachments do you have now?
Do yo have a hyd block?
Do you have a pressure line gong back to the 3pt input?
You need to setup a pressure line QD at the back so you can plug n the log splitter.
If you need the 3pt and log splitter, you need a log splitter valve with PB, so you can have full hyd for everything. .
   / Add Aux hydraulics to Branson 3510 h #4
Here are pics of my 3510 rear hydraulic connections for my Chinese Backhoe.
The fittings are available at a good hydraulics shop and I put an adjustable pressure release (aluminum block) in the circuit for my own peace of mind.
I always store it with the hoses connected as shown.
   / Add Aux hydraulics to Branson 3510 h #5
Can you post the page from the manual about the two ports you use for the log splitter.
Do you still have use of the 3pt?
Does the relief valve have a tee fitting for the relief pressure and is it also the the tank line for the log splitter?
Where is the input port for the 3pt?
   / Add Aux hydraulics to Branson 3510 h #6
Hey Stimw, can you tell me which port on your Branson is the Supply and return in the pictures you shared? The one where the banjo crossover bolts are. Thanks
   / Add Aux hydraulics to Branson 3510 h #7
If you look at the first pic, supply is the front one.
If you look I have the female connector on that line. If the male connector was on it and it was unplugged Hyd fluid would come out.
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2009 Chevrolet Cobalt Sedan (A50324)
2009 Chevrolet...
2002 Fleetwood Expedition 36ft Motorhome (A51694)
2002 Fleetwood...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2016 Ford Focus Sedan (A50324)
2016 Ford Focus...
