Add a rear remote to a Kubota L4310
   / Add a rear remote to a Kubota L4310 #1
thendrix
ball ground, ga
allis chalmers ca
I need info on adding a rear remote to an L4310. What is the best (cheapest, easiest, most effective) way to go about it. It does have a loader.
I didn't see the hydraulics section when I posted this. I'll repost there
   / Add a rear remote to a Kubota L4310 #3
You can tap into the power beyond outlet on the loader valve. Chances are, it is running to the 3-pth hitch right now. You can insert your remove valve into the PB circuit after the loader and then run it back to the 3-pt. The outlet can tee into where the loader outlet dumps, or find out where the factory rear remote kit ties into for the outlet.
Thanks. I'll look into it and report back
2023 John Deere 333G Track Loader (A53485)
2023 John Deere...
Case-IH 370 Steiger (A53314)
Case-IH 370...
2020 DRAGON ESP...
UNUSED I/A 12F 12' HYD BOX SCRAPER (A57192)
UNUSED I/A 12F 12'...
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
King Kutter TG72 Rotary Tiller Tractor Attachment (A54811)
King Kutter TG72...
