Add a rear remote to a Kubota L4310
   / Add a rear remote to a Kubota L4310 #1
thendrix
ball ground, ga
allis chalmers ca
I need info on adding a rear remote to an L4310. What is the best (cheapest, easiest, most effective) way to go about it. It does have a loader.
I didn't see the hydraulics section when I posted this. I'll repost there
   / Add a rear remote to a Kubota L4310 #3
You can tap into the power beyond outlet on the loader valve. Chances are, it is running to the 3-pth hitch right now. You can insert your remove valve into the PB circuit after the loader and then run it back to the 3-pt. The outlet can tee into where the loader outlet dumps, or find out where the factory rear remote kit ties into for the outlet.
Thanks. I'll look into it and report back
2005 Ford F-150 Ext. Cab Pickup Truck (A55852)
2005 Ford F-150...
2005 Freightliner M2 106 Dumpster Carrier Truck (A55852)
2005 Freightliner...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
2017 Vermeer BC1800XL Towable Brush Chipper (A55851)
2017 Vermeer...
2018 Caterpillar 308E2 CR Midi Excavator (A55973)
2018 Caterpillar...
UNUSED FUTURE FT13CJ EXCAVATOR (A57192)
UNUSED FUTURE...
