add a cylinder
   / add a cylinder #1
dixstir
fairmont mn
2305 jd cub farmall home made tractor
I have a jd 2305 it has a loader and a jd manual diverder valve how can I add another double action cylinder and still use my loader controls,
   / add a cylinder #2
What is the new cylinder for?
What do you use the diverter for (I assume the independent MMM lift)?
You can add a new valve that would allow you to operate the MMM and the "new cylinder" one at a time, or even even a 2-spool valve that would let you keep them both hooked up at the same time. If it's for a grapple there is an even easier way...please tell me what your goal is;)
   / add a cylinder
2305 add a cylinder-I want to turn my snow blower chute and may be use it on my hyd traile dump
   / add a cylinder #4
2013 Husqvarna YTH18542 42in Riding Mower (A51694)
2013 Husqvarna...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2002 Ford E-150 Passenger Van (A51692)
2002 Ford E-150...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
2016 Freightliner M2 (A53422)
2016 Freightliner...
