add-a-circuit kit for LED lights
   / add-a-circuit kit for LED lights #11
Your amp draw is insignificant here, even with just a dynamo...........wouldn't worry about it.
Remember you are not running 1-2 rad fans, blower motor, radio, lights, computer.......etc.........as you would in an auto, and certainly not for an extended period of time.
You'll be fine.
For add-on lights I make up my own wire harnesses. In my truck for example I have a separate harness for my head lights, I use the factory light circuit as a trigger only..........same with driving lights and E-fan.
   / add-a-circuit kit for LED lights #12
   / add-a-circuit kit for LED lights #13
If you want the most of your electrical system-
Clean ALL your grounds and connections.
Replace your main cables. Use COPPER lugs and solder-fill your lugs on the cables.
Move and or add ground cables.......add new (additional) ground to dash.........move ground close to starter on engine block.
I use nothing less than 12g wire for lighting and other circuits (except trigger wire......16g is fine). Keep relays near the battery and wires short as possible. Solder and heat-shrink all wire splices.
light tower (A56857)
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
