Adapting A Skidsteer QA To My Kubota B3030
   / Adapting A Skidsteer QA To My Kubota B3030 #11
Ducktape... Thanks for the reply (even though I deleted my question since you were still posting at the time), I ask if all the QA things he buys would have to be cut down to fit...
Great job BTW, very Holy...
Good for use on Sundays! :D
BTW, on your second question, my dogs name is Max (Maxwell). He ends up in alot of my pictures....... not just because he's a ham, but he is with me all day every day.:)
   / Adapting A Skidsteer QA To My Kubota B3030 #13
Man that is a lot of holes you drilled:eek: Looks great though!
Yep, it looks great but if I had $5 for every hole drilled, I could buy that new subsoiler I've been wanting! :) Good job ductape, I wish I was that talented at metalworking.
   / Adapting A Skidsteer QA To My Kubota B3030 #14
Now................ who here lives within a reasonable distance, and has a cutting torch and is good enough with it to remove the old brackets off my bucket (without destroying the bucket) for a twelve-pack ???? :D
Looks like you could grind the welds off with a small 4" handheld grinder, and use a dremel tool in the corners.
Jack
   / Adapting A Skidsteer QA To My Kubota B3030 #15
Nice bit of work there Ductape. In my line of work "universal" means it fits nothing. If it was me I would use a plasme cutter or some grinder cutting disc's to cut the brackets off. A torch will burn a lot of paint off and in some cases will make a mess of things. Just my 2 cents worth.
Well, I made my first attachment last week. I'm always lifting something heavy........ and it sure would be nice to move the trailer around the yard with the tractor. One of those boom pole things might be handy too!
Couple more........
   / Adapting A Skidsteer QA To My Kubota B3030 #18
Top-notch!!! Do you know how much weight you saved with drilling all the holes?
I didn't bother trying to weigh the steel I took out of it...... as a wild guess it was probably only between five and ten pounds. Not much considering the effort, but it looks cool. :cool:
   / Adapting A Skidsteer QA To My Kubota B3030 #20
Ducttape,
Pat yourself on the back, nice work. Don't you guys ever get your tractors dirty? :D:)
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2016 Ford Fusion SE AWD Sedan (A53424)
2016 Ford Fusion...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2021 Harley-Davidson FLHP Motorcycle (A55853)
2021...
21012 (A55853)
21012 (A55853)
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
