Adapt a sears craftsman 4.2kw model 580.327140 generator [generac] to bcs605 tractor
   / Adapt a sears craftsman 4.2kw model 580.327140 generator [generac] to bcs605 tractor #1
lkjhg
The generator cost me $80 but would not start. I thought I could get it running but the generator engine has failed. I want to adapt the generator to my bcs tractor. The generator receives a tapered shaft from the failed engine. I think I will use the failed engine's tapered crankshaft mounted in the crankcase to drive the generator. Machining a tapered shaft to engage the generator and installing pillow block bearings to stabilize the shaft is cost prohibitive. Do you think I can remove the flywheel and bolt a 2-pulley system on the flywheel end of the failed engine crankshaft to get the correct shaft speed? I would remove the failed engine piston but I am concerned about the lobes on the crank causing vibration. What do you think of this project? Am I on the correct path? Its fun to make something out of nothing. I enjoy the process.
   / Adapt a sears craftsman 4.2kw model 580.327140 generator [generac] to bcs605 tractor #2
Probably a 3600 RPM generator. What speed does your BCS run at? Is it the same or higher horse power.
original engine 7.8hp at 3600 rpm. I think the bcs PTO is 1000 rpm. So I will have to install belts and pulleys to get the proper rpm at the generator. BCS605 has a gx390 engine; 13hp
The generac engine crankcase assembly is aluminum [part # 21857a] and receives the steel bolts that hold the ignition coil pickup. Those fittings have been broken off and I do not think they can be repaired. I cannot install the ignition coil pickup. Is this generator rehab a lost cause?
UNUSED CFG INDUSTRIAL 12EX-ATA MINI EXC ATTACHMENT (A51248)
UNUSED CFG...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2018 JOHN DEERE 8370R LOT IDENTIFIER 248 (A53084)
2018 JOHN DEERE...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
UNUSED HURRICANE STAND ON SKID STEER (A51247)
UNUSED HURRICANE...
2014 Caterpillar 289D High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2014 Caterpillar...
