accidently put stabil for gas in the diesel...
   / accidently put stabil for gas in the diesel... #1
Rusty4242
Western Mass.
Kubota BX23
Gents, to make a long story short, I accidently put stabil for gas in 5 gallons of diesel fuel for my BX23 Kubota. Should I dump it ( in an enviromentally proper way, of course) or can I use it? Thanks, Rusty
   / accidently put stabil for gas in the diesel... #2
Should be ok how much did you put in?Small amount like a few ounces no big deal.:thumbsup:Dave
   / accidently put stabil for gas in the diesel... #3
I thought it was labelled for both. You might look on their website.
But I wouldn't worry about it in any case. I think it simply kills bacteria.
   / accidently put stabil for gas in the diesel... #4
I agree with California, should not be a problem.
   / accidently put stabil for gas in the diesel... #5
Older containers of regular Sta-bil were recommended for diesel as well as gas.
Now there is a special diesel version. I doubt it will hurt anything.
Ordinary Sta-bil is an antioxidant which prevents gas from gumming. I think the diesel type kills bacteria.
   / accidently put stabil for gas in the diesel... #6
Sea Foam uses the same thing for gas, diesel and ethanol I know. You should be fine.
   / accidently put stabil for gas in the diesel... #7
I used Sta-Bil for gas in my diesel without problems. The old bottles said it was good for both fuel types.
Thanks for the reassurance. I put in the standard 4 oz stabil to 5 gal of fuel.
I'll go ahead and use it, maybe but it 50/50 with clean diesel. Thanks,again, Rusty
   / accidently put stabil for gas in the diesel... #9
4 oz of it to 640 oz of fuel is noting. Thats like mixing 160 to 1.
Chris
   / accidently put stabil for gas in the diesel... #10
Chris
ditto that.. it's such a dilution it shouldn't matter... even with straight alcohol..
soundguy
LOT: (2) Almost Full Jugs of Komatsu Coolant, (1) Almost Full Jug of Liebherr Coolant, 1/3 Barrell (A59076)
LOT: (2) Almost...
2019 INTERNATIONAL RH613 (A58214)
2019 INTERNATIONAL...
1994 EZ-GO Golf Cart (A56859)
1994 EZ-GO Golf...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
CASE TR340 SKID STEER (A52709)
CASE TR340 SKID...
Magnum 4000 Series Hot Water Pressure Washer (A55272)
Magnum 4000 Series...
