AC WD hydraulic problem
/ AC WD hydraulic problem #1
shop hermit
ks.
AC WD
I have a wd with a hydraulic problem. Sometimes...usually upon first starting up...the hydraulics work normally the first time used. Then they work very slowly, but at normal pressure. Takes at least 30 seconds to raise the loader bucket to full height. Once in a while during subsequent operation it will lift at normal speed for one cycle, then resume the slow-lift thing. All the adjustments are correct as far as I can tell. There is some leakage of transmission oil into the hydraulics and it is a little too thick, but would this cause the intermittent operation. It acts as though only piston in the pump were working. Put some Rislone in but it didn,t help.
/ AC WD hydraulic problem #3
AC never did have a working hyd. system!!----I have 3 wd's and 2 wd-45's and the hyd. does NOT work on any of them!----The best fix is to mount a real hyd pump (either live or pto drive) and junk the ac system! ----I did this for a buddy of mine and now he uses his 45 all the time!! thanks; sonny580
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
More info coming soon (A61574)
More info coming...
2021 International HX620 Quint Dump (A62613)
2021 International...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
