AC Question
   / AC Question #1
Toddfromtexas
Massey Ferguson 3660
Recently purchased a 94' 3660, air blows but not cooling. Cleaned coils, Compressor is kicking in and cycles when temp. is adjusted.
I am looking to check freon levels, but only finding 1 fitting on the back side of the Sanden compressor. Should there be 2 a high and low side if so where an I missing the other fitting.
   / AC Question #2
I haven't seen a system that did not have both fittings for your gauges. Normally, the high side pressure line should be the smaller line going to the compressor and the suction (low pressure) side should be the larger line. Try tracing those lines backwards from the compressor and see if you don't find a separate fitting in each line somewhere in the plumbing. Not so easy to find in some set-ups...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
2012 RAM 2500 (A53843)
MURRAY PUSH MOWER (A53843)
MURRAY PUSH MOWER...
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
2007 Yamaha Rhino 660 (A55218)
2007 Yamaha Rhino...
ALLISON TRANSMISSION (A53843)
ALLISON...
