AC B hydraulic pump.
/ AC B hydraulic pump. #1
Dstrnad
South Boardman, MI
Allis Chalmers B
I have an AC B with factory hydraulics, I took the pump apart to clean before i use. The oil was milk shaked and I have never used before, just got the tractor. Anyways I now have a left over check ball the size of a BB. Not sure where it goes. Does anybody have a breakdown of the pump? Also on the pump plungers there are two small groves, are there supposed to be o-rings on these? The only seal appers to be on the lever shaft?
Thanks
Dave
/ AC B hydraulic pump. #2
There are five balls total. One suction ball and one discharge ball for each of the two plungers plus one relief valve ball. I'm not sure if they are all the same size or not. The plungers do not have o-rings.
Thank you so much,very helpful. I found 1 ball is missing and the other in the wrong spot. Does anyone know how the intake ball check sleve comes out. The pin and ball is missing. Is it pressed in or threaded?
Thanks
Dave
/ AC B hydraulic pump. #4
They are pressed in. They should be internally threaded so you can use a puller to remove. I understand some were not threaded however. I have sent you an email via Tractor By Net.
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
2005 Katolight VSD60FGJ4 60kW Standby Diesel Generator (A61572)
2005 Katolight...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
2022 John Deere 325G Track Loader (A63111)
2022 John Deere...
Harrell 6710 (A64119)
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
