AC 8030 pulling trailer?
/ AC 8030 pulling trailer? #1
kfin
Central, MO
YM2310D
I have an AC 8030 2 wd with a full rack of weights in the front. also have a 16' flatbed trailer with dual 8,000 lb axles but it has a ball hitch on it. I want to use this for hauling loads of firewood about 7 miles in the country......possible to hook this trailer to a ball hitch? Good idea or not?
/ AC 8030 pulling trailer? #2
Your trailer has a ball hitch or a gooseneck? Just seems like a lot of weight for a ball hitch.
It is possible, but if a gooseneck getting the correct hitch height will be an issue.
I know a few people who have a 3 point hitch set up to move a gooseneck around. They only use it for cattle trailers to move one or 2 cows at a time between barns.
I myself used to move a pintel hitch flat bed trailer around with a dozer. The tractor was 100 hp 4wd and it basicaly only was used to cross the road.
/ AC 8030 pulling trailer? #3
We have an 8050 2WD so I can relate to your issue...
Those tractors were marketed by Allis as quick turning due to a short wheel base...
You may have enough weight on the front to handle the hitch weight but it could be iffy...
I pull a 10' Howse bush hog on the 3 point with our 8050 and without weights on the front she will get light...
I think that Allis manufactured two weight brackets for the tractor...
A 14 and a 10...
/ AC 8030 pulling trailer? #4
I don't think you will have a problem. I have a ball on my tractor for my 7 tonne trailer. I haven't had it on the road but I'm pretty sure it would handle it fine at speed. Not sure how heavy your tractor is, but from a pic it looks at least as heavy as mine.
/ AC 8030 pulling trailer? #5
I've spent many hours running 8030, 8050 and 8070 AC's, they were great tractors. We used to pull a 500bu grain cart with them, loaded it weighed about 34,000lbs, so what you're describing should be no problem at all. Just be sure to find one of the 1 1/4" shank hitch balls with a high weight rating.
2016 PETERBILT 579 4X2 S/A DAY CAB TRUCK TRACTOR (A59908)
2016 PETERBILT 579...
New/Unused Quick Attach Skid Steer Brush Cutter (A61166)
New/Unused Quick...
2021 Takeuchi TL6R High Flow Compact Track Loader Skid Steer (A61567)
2021 Takeuchi TL6R...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
DEUTZ MARATHON...
