Above ground pool project
   / Above ground pool project
Jerry,
Others are interested so if you wouldn't mind I'd like to know how to run this wire correctly. I will be starting at a 20 amp breaker in the house. The system is grounded but I wondered if adding one at the post would be a good idea. I bought 250' of 10/2 UF wire, a weatherproof box and locking cover for the 20 amp GFI plug that I was going to mount on a 4X4 pole 10' from the pool.
Thanks,
David
While I wait to hear about the electric, I wonder if anyone out there can help me with the landscaping. I had to cut into a banking to get a level area for the pool. I am worried about rain water runoff above the pool. I'll post some picts to give you an idea.Pool project day 2.Oh yeah, Had to buy a landscape rake for this project.:)David
We grow rocks up here
Landscape view1 of 3
Landscape view 2 of 3
Landscape view3 of 3
   / Above ground pool project #17
David,
Sounds like most of your plans are on track except for the 10/2 UF cable. The NEC requires an insulated ground in your wiring method to a pool.
If you decide to run cable (for whatever reason you chose) it needs to be 24" below grade. PVC conduit can be 18". If you mount the post closer than 5' to the pool then a regular outlet is not going to work, a twist-lock outlet must be used to keep anyone from plugging anything in and somehow it ending up in the pool. But if you mount it 10' away, it will be ok with the GFCI outlet. Keep in mind the cord on the pump may not be 10' long, some are, some aren't.
A bond wire (minimum #8awg solid) must be installed from the outer casing of the pump motor to the metal parts of the pool. This is done to make the metal of the pool and the metal of the pump "the same". Limits differences of potential between the two.
The only benefit to driving a ground at the post would be for lightning dissipation. The earth MAY NOT be used as the sole means of ground. So driving one there is not much of a benefit. Actually, the one at the house is for the same purpose, more or less. A fault to ground will always try to go back to the point of origination, using the path of least resistance, of the electric supply. So trying to coax it to go back through the earth, well.........lets say it would take it a day or two. The insulated wire from the house will serve that purpose very well. It will also make the circuit breaker open where as the ground rod won't.
I hope this helps you. And hopefully I haven't confused anyone.
By the way........the lad at Home Depot had a code book he was looking at.......? I can't find anywhere in there where it says only if you go through a garden you have to use conduit. They do try to hire people knowledgable in trades when they can, but they have to take breaks too, and some poor lad will take his place.
   / Above ground pool project #18
<font color=blue>I wonder if anyone out there can help me with the landscaping. I had to cut into a banking to get a level area for the pool. I am worried about rain water runoff above the pool. </font color=blue>
Looks like you've done quite a bit of digging. Make sure that your level area is a good bit bigger than the pool size. I'd say about 5 feet all around. The oval pools (at least mine) have angle braces on the sides that stick out an extra 3 feet or so. Even if you are going to be putting a deck around the pool, it helps to have a flat area all around it for ease of access for maintenance (winter covering, etc). Another thing to check on is the local requirements on height from the ground to the top edge of the pool. Most places require at least 48 inches to prevent little tots from climbing/falling in. If the bank cut is right next to the pool, you will have to make up the difference with a fence of the proper height. I would taper the bank cut back to make a smooth transition back into the lawn. Plant some flowers and/or shrubs... some wood mulch and you're all set /w3tcompact/icons/smile.gif.
Include provisions for adding a light pole somewhere nearby. Looks like your pool is a good ways away from the house (like mine). Its nice to have the pool area light(s) for swimming at night.
Hve fun!
John
Jerry,
When you say "an insulated ground wire", do you mean covered like the other 2 wires? Is that something I can buy like the UF wire? What is the reason for the insulated ground?
Thanks for all the info.
David
   / Above ground pool project #20
David,
In short......UF cable is not permitted at all. The following was cut from the NEC 2002 Article 680.
680.21 Motors.
(A) Wiring Methods.
(1) General. The branch circuits for pool-associated motors shall be installed in rigid metal conduit, intermediate metal conduit, rigid nonmetallic conduit, or Type MC cable listed for the location. Other wiring methods and materials shall be permitted in specific locations or applications as covered in this section. Any wiring method employed shall contain a copper equipment grounding conductor sized in accordance with 250.122 but not smaller than 12 AWG.
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2016 Ford Transit 250 Cargo Van (A50323)
2016 Ford Transit...
2015 Kia Sorento AWD SUV (A50324)
2015 Kia Sorento...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52128)
2022 MAXXD BD14...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
