About this pedal thang
   / About this pedal thang #11
After using manual tractors for ever, going to a HST is a no brainer. The amount of precise control you can have without blowing up a clutch (riding the clutch) is amazing.
   / About this pedal thang #12
First tractor was pure gear type. Second was a hydro, a NH 1925. It was ok, tractor was simply too lightweight for what I was doing. But something about the pedal was comfortable to use.
Current tractor is geared, shuttle shift. I like it a LOT better, control is great, can use split brakes. Forward/reverse is a simple lever flip, no clutching required. Best way to go I think for a geared tractor.
Neighbor has a new Kubota hydro, and the few times I've been on it, the pedal seems awkward to me....sits too far back or something.....can't quite put my hand on why....just doesn't 'feel' right to me. Hard on my old leg to use.
And for all the people that complain about the cost of replacing a clutch, if they ever have to price work on a hydro unit, they will stop complaining.
   / About this pedal thang #13
I'm likely going to be buying an L2501, 3301, or 3901.
Never owned a Kubota.
Never operated a "tractor" with a Hydro tranny.
I have a JD lawn tractor with Hydro.
I understand that after a bit of time most seem pleased with the Kubota bi-****** pedal treddle thang. But, it sure feels clumsy to me by just resting my foot on it.
I've yet to operate one, so my concerns about the comfort and user friendly part of it may be for naught.
I'm curious how many folks buy the Kubota HST because it "just seems like the thing to do".
Are there any of y'all that a dead set on using a geared tranny?
Another thing that I don't care for on the models I'm looking at, is the brake pedals are on the same side as the pedal thang.
On other tractors I've operated, they were all geared trannys and I used the heck out of one wheel braking. That's not possible with these.
Anyone else miss that feature?
I would like to like the HST but wondering if a geared unit would be a better fit for me.
Most of my use initially will be using a brush hog in tight quarters to cut/chop and maintain underbrush. (9 acres heavily wooded)
Moving the brush to burn piles.
And maintaining 600' of driveway, til I die.
I remember the days of using a box blade and the geared tranny. That was a workout at times.
All opinions appreciated. thank you
Undecided and still kickin tires
At least on mine, it actually acts like 2 pedals because the overall pedal is an upside down L shape. So I use it just like a car. Gas foot to right of main pedal. To reverse I take my foot off the gas and move it down and to the left for reverse. You get used to it in a few hours. Do not keep your foot on the top of the pedal all the time (at least on mine). Hope the L is the same.
Yessir, exactly what I thought about the pedal. Sits too far back and seems I'd have to holding my leg up over it.
Arthritis sucks.
My son in law bought a Mahindra a few months back. I was quizzing him about it on Thanksgiving and he claimed he really liked it.
It has shuttle shift. Never even heard of it til I started lookin to buy a tractor.
Believe I'll go run his a bit and see how it behaves. However, I'm not real sold on Mahindra and a dealer for where i'm retiring to is not very close.
   / About this pedal thang #15
I use to own a TC25D with a treadle pedal (HST) for several decades and absolutely loved it. Never one issue with it nor did I ever wish it was different. I now own a single "go" pedal CVT tractor. I like it too quite a bit. I also had a JD with dual side-by-side pedals which I did not care for. I was never sure where my foot was on the JD and if I did not look I was not positive which pedal I was gonna push.
The reason I bring them all up is because I have a 2 acre pond and at times need to inch right up to the edge of the pond and drop my loader into the water to drag up mud/dirt to plug muscrat dens, holes, etc or pull out trees that have fallen in or even to get a loader full of water to dump on some newly planted trees needing water in the summer etc.
With the treadle pedal I always had 100% confidence I could inch right up to the edge and if I felt I was even an inch too far in and the front tires starting to sink I could, in a wink of an eye, back the tractor back up by leaving my foot exactly where it was and just roll my foot backwards. It offered the single most and quickest positive response to make the tractor go where I needed it to go.
My current CVT machine is a bit scary to do the same thing since I have to slap the F/R lever on the left side of the steering column to make the tractor go in one direction or another......that takes about 1 second. May not sound like much but when your front tires may have gone too far forward and you want to get ur A$$etts back out backwards that 1 second can be a puckering second.
The dual pedal design IMO fits between the two......it is maybe a split second quicker to change directions than my CVT IF you are positive where your foot is and where the reverse pedal is but it is not as positive and instantaneous as the treadle pedal.
Given a choice of all 3 I would jump back to the treadle pedal in a heart beat if I could get it on my CVT. 2nd place goes to my CVT and 3rd to the dual pedals.
   / About this pedal thang #16
The geared 2501 and 3301 don't have a live PTO, which will reduce the efficiency of your brush hog and other implements.
If you do go with a hydro, consider getting it with cruise control; that way you don't need to constantly hold the pedal down.
The Mahindra 1600 series is a nice looking setup, I thought about trading the 3301HST which I bought last year but can't justify the expense.
If you do stick with Kubota I would get the geared 3901, which is what I wish that I had bought last year.
   / About this pedal thang #17
I have owned two HST Kubota tractors;only way to go IMHO.I don't rock my foot;pick up and move to reverse.
I also have a JD mower with the two pedal set-up;that's o.k. also,no problem going from one to another.
We have two geared "L"Kubota's also,no shuttle and they work fine just not my first choice.
   / About this pedal thang #18
I own a Kubota sub-compact. I have also spent hours brush hogging on my father-in-laws JD compact. It is also a hydro but has separate pedals. I found them to be equally easy to maneuver, even in tight spaces. I would say do a demo of both and see how it feels for you. My uncle has a brand new Manhindra shuttle shift. I haven't tried it yet but I probably will in the spring. It makes a lot of sense to me to get a geared tractor if you are doing mostly ground engagement -- which he isn't -- so it will be interesting to see how he feels after he's owned it for a while.
   / About this pedal thang #19
The peddle took me a little while to get used to, now I like it. Big mistake placing your foot on the top and "rocking" back and forth. Its just way too uncomfortable for anyone over 5ft tall. Use your toe on the forward end and rest your heal on the floor board. For reverse, lift your foot and place your toes where your heal was, and heal on the rear part of the peddle. Yes, its more movement of your leg, but way easier to control.
While I agree that the split brakes are useless on these models unless you have cruise control, they actually don't need them. I used the split brakes on my 770 a lot, but the 2501 seems to turn better. With a 5ft mower on the back, I think you'll be able to get to everything you need to.
I do like to use the split brakes as a "locker" though, and apply power to the rear wheel of my choice. Hard to do on this machine.
Would I chose gear over hydro next time? No way! This machine so nimble and controllable, I could never give it up. For close quarters, its amazingly handy. The 2501 will do any ground engaging and loader work you can throw at it, but If you need a lot of PTO power, the higher power model (3901) may be a better choice. I've had mine bog in heavy growth with both the 6ft finish mower and 5ft bush hog on and had to slow down to clear it out.
   / About this pedal thang #20
i find myself simply hooking the toe of my shoe under the forward treadle & lifting up. I'll typically do this unless reversing for a long distance, then I'll move my heel back to the reverse treadle.
2018 JAGUAR XE Sedan (A56859)
2018 JAGUAR XE...
LANDPRIDE 5' ROTARY MOWER (A58375)
LANDPRIDE 5'...
(2) STATIONARY IRRIGATION GUNS (A58375)
(2) STATIONARY...
2018 GMC Sierra (A57148)
2018 GMC Sierra...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
Single Cedar Glider (A57454)
Single Cedar...
