ABC Speed Range hard to shift
/ ABC Speed Range hard to shift #1
ShotgunMiss
Methow, WA
JD 4320
Hi All,
I just purchased a new JD 4320 with cab and eHydro transmission. I've lost two nights sleep reading the manuals, but I can't wait to get out and figure it out.
Today was my first day of learning the controls. The speed shifter seems really hard to shift. Is that normal? Since there is no clutch am I supposed to push the brake or throttle pedals as I go to another speed? I need to look, but I thought it said to be stopped before you shift the speed range. I am, but geez....it's tough to move! Any help?
/ ABC Speed Range hard to shift #2
Welcome.
Need to be stopped completely. If the lever is hard to budge, give it just a hair of forward pedal while moving the lever. If still in a bind try just a hair of rear pedal.
I have the same setup (4120 ehydro) and it does the same if it's in a little bind. It's normal.
/ ABC Speed Range hard to shift #3
You might try briefly touching the reverse pedal especially if using 4WD. This will help release any binding of drives between frt & rear tires.
Tx Jim & dusty3030, thanks for your advice. I'll give it a try this morning.
/ ABC Speed Range hard to shift #5
Don't force it! I hear they are easy to snap the shaft at the trans housing.
/ ABC Speed Range hard to shift #7
As dusty3030 posted, just a light tap of the reverse pedal will normally do the trick.
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
New Holland 3930 (A62177)
New Holland 3930...
UNUSED KUBOTA K7875A EXCAVATOR BUCKET (A62130)
UNUSED KUBOTA...
2012 Toyota Camry Sedan (A61569)
2012 Toyota Camry...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A60352)
2012 Kenworth T800...
