A super middlebuster?
   / A super middlebuster? #1
RobJ
Elite Member
Spring, TX (Houston)
Kubota L2500
Next new attachment for the homemade toolbar. I found this around a pile an old Farmall Super M. There were 2. Just an early turning plow for this tractor? It may not look that big and heavy, but just what you see must weigh2 over 125 pounds. I can barely lift it. the horizonal bar is solid 1.25"x2.5".
Anyone know anything about the different nose pieces? Looks like they all fit the tool but are slightly different.
Rob
   / A super middlebuster? #4
I'm curious how wide the wings on the plow are and how wide a furrow it would make?
I cut the holes in the bar last night and stuck it in. The top of the plow is 12". To the bar it's 21". Total width has to be 17-20". I didn't measure that this morning.
We'll know how wide and how deep in a couple week!! :D
Rob
   / A super middlebuster? #6
If you could find another like it for the toolbar, you could use the pair to semi-hill potatoes with. Depends on your row spacing, of course. Straddle a row and dig out the row middles.
hehe, there is another out there. they probably won't miss it.
   / A super middlebuster? #8
Rob, I have a middle buster for my row cultivator. It was once a horse-drawn implement I believe...maybe not. Anyway, there are two angles welded to it's sides and drilled so it mounts on the cultivator. I think your mounting will be fine except you will need to support the part that extends out front. If you hit a rock while that middle-buster is buried, it will twist and deform that beam like it is taffy. That plow will have much more resistance than scarifiers on a boxblade. Nice job so far.:)
   / A super middlebuster? #9
I found a picture of my middle buster.
Looks about the same to me. I like the rest of the rig to!!
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
2020 Case IH 8250 4WD Combine (A50657)
2020 Case IH 8250...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
2011 MAGNUM PRODUCTS LIGHT TOWER/WATER TANK TRAILER (A50854)
2011 MAGNUM...
1 guard rail (A49346)
TEST BID LOT (A50775)
