A simple oil change.....Negative
   / A simple oil change.....Negative
Why wouldnt a little anti seize compound take care of this
Are you saying to use it before the threads striped? I doubt that would help, since the plug is always threaded in while oil residue is running out. I think the alloy is just a little too soft...need to be tweaked.
   / A simple oil change.....Negative #12
seems like a very strange failure mode. there is little torque and no stress on a drain bolt. i have seen similar problems on engines with aluminum blocks and heads but the fasteners in those applications had high torque. Anti seize was a must on them.
   / A simple oil change.....Negative #13
sounds liek a design issue... needing torque to seal vs providing for a good gasket or oring seal and low torque.
What is an "off" plug? I'm not familiar with that term.
That's the plug on the other side of you. I guess I get that from horse teams...near horse and off horse, or if your mounting it's near side and off side.:horse:
   / A simple oil change.....Negative #16
you kinda have to be an equine person to get that.
kinda like gee and haw.. :)
   / A simple oil change.....Negative #17
   / A simple oil change.....Negative #18
OK Ford diesel guys.. if you are cringing at the idea of a plastic pan on a 20K dollar tractor... you will REALLY cringe at the idea of a 6.7L Ford Diesel having a plastic oil pan and valve covers!!.. And yes, mine is leaking... has been for the past 20K miles... Dealer keeps working on it...
Aluminum oil pans are great.... As long as the threads are cut right. it also needs to be built up thick where the threads are... not paper thin. If at all possible, install a Fumoto valve or simple ball valve so that once installed, you wont be unscrewing it anymore.
   / A simple oil change.....Negative #19
I know it's not likely but is there any chance you cross threaded it when you put it in last time? Or do you think the heat "siezed" it in place?
Re plastic oil pans, I never knew that. Aye carumba.
   / A simple oil change.....Negative #20
The 6.7 doesn't have a traditional thread in drain plug. It's a plastic drain plug , with an oring, that goes in and turns 90 degrees. That is the only plastic engine oil pan I can think of. Ford has gone to plastic on some of their transmission pans also.
Chuck
Pickup Instructions (A55272)
Pickup...
2017 Jacobsen Greens King IV Plus Reel Commercial Mower (A56857)
2017 Jacobsen...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
2016 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2016 Nissan...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
