A scary situation
/ A scary situation #1
songhunter
Chattanooga, TN
New Holland TC18
I have a small tractor without a ROPS and seatbelt. Since most of the ground is fairly level, I figured I'd be okay for mowing and light cleaning. I have a small bush hog I use to clear out briars and small brush.
I was cleaning a small area on a gentle slope to prepare an area to plant a few more blueberry plants. I was using the small bush hog when the left side of the tractor suddenly raised up very high. I didn't know at the time what had happened. I pushed in the clutch that stopped the tractor's forward movement and the bush hog. The left side of the tractor was so high I could stand on the ground with my right leg unextended /forums/images/graemlins/shocked.gif The right side of the deck was almost touching the ground.
I looked down and the left rear wheel of the tractor had climbed a stump I had left several months ago. When I regained my composure, I put the tractor in reverse and backed down the stump. I felt like an idiot! /forums/images/graemlins/crazy.gif
I always figured I could jump free from a rollover. I have pretty good reflexes and I figured I'd have plenty of time. If this experience is any indication of what a rollover would be like, there's not hardly any time to take any action. Then there's the question of where to jump. Jumping to back is a no-no. The pto and mower are back there. Jumping to the low side seems inappropriate, since that's where the tractor is going. Jumping over the hood is out, since I'd never make it in time. Jumping to the high side would almost be impossible.
I believe I need to invest in a ROPS and seatbelt, or maybe a tractor that already has one. /forums/images/graemlins/smirk.gif
/ A scary situation #2
Phew ! Close call !
Accident
1 a : an unforeseen and unplanned event or circumstance b : lack of intention or necessity : CHANCE <met by accident rather than by design>
2 a : an unfortunate event resulting especially from carelessness or ignorance b : an unexpected and medically important bodily event especially when injurious <a cerebrovascular accident> c : an unexpected happening causing loss or injury which is not due to any fault or misconduct on the part of the person injured but for which legal relief may be sought
3 : a nonessential property or quality of an entity or circumstance <the accident of nationality>
Dave...
/ A scary situation #3
Bruce, I am very glad you are alright!!! In the past, there have been people on TBN who have claimed that their reaction time will save them. Your example shows that's not a smart assumption. /forums/images/graemlins/frown.gif
/ A scary situation #4
Dave...... are those definations from a legal dictionary????? You must be an attorney!!!!!!!! /forums/images/graemlins/grin.gif
/ A scary situation #5
A near miss is a lesson which (if learned) may save one from unfortunate circumstances at a future time.
I try to learn from mine and it sounds like you do too!
Glad your experience turned out to be a near miss... /forums/images/graemlins/smile.gif
/ A scary situation #6
Thanks for sharing your experience, and I suggest you take the time to read the posts titled: "What not to do with a backhoe". After reading some of the accident reports that Junkman provided a link to I will NEVER fail to put my ROPS up when using my tractor.
/ A scary situation #7
When I first received my tractor I quickly got good with it (so I thought) and was mowing in high gear making great time. I went around some brush and hit a hidden stump. One rear tire bounced up about a foot, although it seemed like three. A little more and I think it would have gone over. It was up and then back down before I knew it. There was no time to react. Period. Scaird the death out of me and made me slow down from then on.
/ A scary situation #8
Experience is a tough teacher. First you take the test, then you get the lesson. Sounds like you survived and learned the lesson.
Please be careful!
/ A scary situation #9
I know that if you drive a tractor long enough, your going to get into a scary situation. My scariest situation happened when I owned a sub-compact (20HP, gas, hydro) with a small FEL. I was driving straight up the hill in my back yard (1200 ft long with about 100 foot drop) with the loader on and a counter weight in back. My mound system is at the very top of the hill and as I climbed the last few feet I realized that I had forgotten some tools at the bottom of the hill. After I got to the top flat section I turned arround to head back down.
The tractor has a lever on the left side fender for turtle/rabbit selection and neutral in the middle. As I started down the mound, the selector popped into the neutral position. I went from 0-60 MPH in less than a second /forums/images/graemlins/ooo.gif. Stepped on the brakes and nothing happened /forums/images/graemlins/ooo.gif. All kinds of things went through my mind in that very fast ride! Do I drop the loader? No, it may flip end for end! Do I try to turn? No, it may go into a high speed roll! Do I jump? No, going way too fast. Everything went through my mind except... drop the weight.
So here I am riding this 1800 lb run away machine straight down the hill. About a third of the way down is an old fence row, no posts or wire, just a bump and a 4 foot drop to the next field. I hit that and came straight up out of the seat. I was able to hang on to the steering wheel and landed back in the seat, still going 100 mph /forums/images/graemlins/shocked.gif. Just when I thought the excitement was over, another old fence row. You guest it, back out of the seat I go, again landing back in the seat to continue my ride down that hill. When the beast finally came to rest, the only damage was bruised knee's (from hitting the steering wheel) and a bruised ego.
After I changed my shorts, I measured the distance of my two "jumps". The first one the tractor was in the air for 8 feet, and 12 feet for the second one. Any time that I used the tractor after that, I bungee'd the lever into position. I sold the thing soon after /forums/images/graemlins/smile.gif
/ A scary situation #10
Wow Stumpman--I think you might win the prize!
Great idea to bungee the lever........
/ A scary situation #11
Wow...UP to now I have seen posts about wheelies, hands stands, one wheel up...and so on...
But Stumpman, I think yours may be the first report of a flying tractor...all four wheels off the ground at the same time...on a tractor complete with loader and rear ballast...
Wow... /forums/images/graemlins/shocked.gif Glad you are still here to report it!
/ A scary situation #12
I think that you should change your name from Stumpman to Stuntman!!!!!!! /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/blush.gif
/ A scary situation #13
Was that tractor a Beechcraft or a Cessna?
/ A scary situation #14
I turned my tractor (w ROPs) two summers ago. I was able to jump off befor the tractor tipped into the pond. Outside of the obvious safty benefit, another benefit for me at least, was that the ROP prevented the tractor from rolling fully into the pond!
Buck
/ A scary situation #15
A runaway tractor and no way to get it stopped. We will all be having nightmares about that story. You should indeed get a set of wings like the pilots wear for that one Stumpman.
Glad you are OK. /forums/images/graemlins/grin.gif
I have a pond on my property and whenever I use the tractor in close proximity to it the hair on the back of my neck stands up. I would hate to think what could happen if a wheel hit a soft spot.
/ A scary situation #16
The worst part of that whole thing was that I had to look at the wheel tracks through the long grass for the better part of two summers. Every time I would see them or have to explain them to friends, it would send shivers down my spine just thinking what could have happened.
/ A scary situation #17
Wow, stumpman, what a horrifiying story! Glad to hear you're ok. I can't even begin to imagine what that must have been like! /forums/images/graemlins/shocked.gif
2007 WESTERN STAR  4900 TRI AXLE (A67714)
2007 WESTERN STAR...
2015 GMC Savana (A64911)
2015 GMC Savana...
Rhino MDB 130 (A64911)
John Deere 6405 (A64911)
John Deere 6405...
2017 Autocar Xpeditor T/A EZ-Pack 40yd. Front Loader Garbage Truck (A66736)
2017 Autocar...
2009 FORD CROWN VICTORIA CAR (A66091)
2009 FORD CROWN...
