A question on top links
   / A question on top links #1
OzarksHermit
SW Mo, on Table Rock Lake
Kubota BX25
Howdy
How "flexible" are the ball joints on each end of a top link supposed to be?
I just purchased a CAT 0 top link for my home made thumb, and the ball joint on each end was at quite an angle to the threaded rod. I finally straightened it by inserting a short length of steel rod into the hole, and using a lead hammer was able to pound on the rod to make the hole at 90 degrees to the shaft. Man, that ball joint is really tight. It would seem that the ball joints should move a little more freely to compensate for alignment.
Any suggestions?
Thanks
Ken
   / A question on top links #2
Once you get it on, it will get loose soon enough. Ken Sweet
   / A question on top links #3
Yep, just needs to limber up. If it's rusty, maybe a little WD-40 but don't grease it... that will just attract more dirt & crap to gunk it up.
   / A question on top links #4
When new the balls are extremely tight. I put some Fluid Film on them and they miraculously loosened up instantly.
After they get used for a while you can just leave them dry unless they start to rust. Then Fluid Film can do its magic again - very good preservative.
   / A question on top links #5
The eyes on my links had paint on them.. A bit of lacquer thinner and some brute force to get'm moving took care of it.
But yeah, if you can put up with them being tight for a short while, they will get plenty loose eventually.
   / A question on top links #6
nothing to worry about. all top links and swivel eyes from 3pt are tight when new. As you use them, it will work itself loose which is why its tight to begin with, over time it will be very loose.
Since this is for your thumb, keeping it aligned , should keep it nice and tight for a long time unless your thumb and boom of BH flexes some.
Unused 2025 CFG MX15RX Mini Excavator (A50322)
Unused 2025 CFG...
2018 JLG 3246ES 32FT. Scissor Lift (A51691)
2018 JLG 3246ES...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
Case IH 2608 8 Row Corn Head (A52349)
Case IH 2608 8 Row...
2020 Toro 6000 Series 60in Zero Turn Commercial Mower (A50322)
2020 Toro 6000...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A52748)
2012 KINZE FLAT...
