A newbies DIY solar install
   / A newbies DIY solar install #221
I recall being told that before you consider solar - in order to have it correctly sized and not oversized for your usage - you should first do everything else to reduce your energy usage. This is because they (at least in my case) sized the solar set up based on the last twelve months of energy usage. I suppose they mean put in LED bulbs, clean filters, maybe switch out energy efficient appliances, and more. We had already done most of that - and we were not about to buy a new refrigerator or spend too much that way. So far, it seems the sizing was correct - we did have a $151 Tru-Up bill at the last anniversary of our installation - but our daughter and SIL are living with us while they build a home here - and were not here for that twelve-month billing stint which they used to size the solar installation. They live in a separate building so more AC, lights and such. Very happy we went solar - as mentioned before here - saving about $4,000 a year and likely more now that rates have increased.
You should also tell them if you are contemplating adding something that will use a lot of electricity - pool, hot tub, AC - so they can figure that in as well.
I sized mine for growth, understanding that with free/cheaper power (especially during the day), I'm more likely to keep the house cooler than previously - we've often made do with windows & doors open when "it's not THAT hot!" and last summer we actually closed the house and went for AC at much more reasonable temperatures...
IMO it's cheaper to overbuild a bit today rather than try to make it a bit bigger later - it's a money-losing proposition to upgrade the solar panels after 5-10 years vs choosing slightly bigger ones today.
That said, I did also set up my system so that I can easily add another array 50% the size of the current one by making sure the wiring is sized for that (kinda part of the overbuild; spent an extra couple hundred on going up two sizes in wire to the ground mount) - in case / for when we add an electric car like my wife's been threatening (the system uses edge inverters, so there's no inverter to upgrade, and the main system switch is capable of handling the increased current with a breaker change, and there was no smaller capability switch available for this system).
   / A newbies DIY solar install #222
Time for another project. This one is a new solar install for the house. Figured I would document my experience and hopefully get some help/advice along the way and maybe help someone else considering a diy solar install. We've had solar on our business for 8 years and has done great and figured it's time to look at doing it for the home.
System will be grid tied. I started out thinking I would do a turn-key install. Recieved 3 proposals, with the best but all close coming in at $52k or $38,500 after tax rebate. That put my ROI at about 9 years based on output and current electric bill and not factoring any repairs. After looking at the numbers I decided to price out a similar self install kit for comparison and was shocked at the price difference. $20,009 shipped to my door or $14,800 after tax rebate so self install it is. Kit includes everything needed other than the 3" pipe for the iron ridge ground mount and any knowledge of what I'm doing on my end but I figure for $23k I can figure it out. Payoff should be less than 4 years if it covers as much of my electric bill as expected.
System details:
25kw system
2 - Fronius Primos 12.5 investors
60 - Trina Solar 410 watt panels
Iron ridge racking systems
Currently working on the application and approval with our electric coop before making the purchase and will update as this project moves forward.
Jeremy
I was going solar on my house in California.
Electricity is very expensive there and I had it figured out.
Electric Co. is now charging for the solar you produce along with a cost for being on the grid. They can charge you for the solar even if not connected to electric co. PUC has agreed with all this.
I sold the house and moved out of California.
   / A newbies DIY solar install #223
I agree with you that electricity is very expensive in CA.
However, the rest of your message is worth what I've paid for it.
There is a proposal for a "grid participation charge"; it's not in place yet.
It is for a grid connection, and as such obviously is not charged if you're not connected to the grid.
Hope you found somewhere to live that matches you better.
   / A newbies DIY solar install #224
I don’t know which electric provider you had, but SCE pay me for ALL the power I produce, but at a lesser value than power I buy at peak times. I have never heard of ANY electric company charging you for off grid production. You’re gonna hafta provide a citation to make that believeable.
My total electric cost for power last year was $165. Before solar over $2000.
   / A newbies DIY solar install #225
Right now we have to pay about $30 a month to PGE even though we have solar. We have to pay $5 per meter - a fee so we can remain hooked up to the grid - and we have two meters so that is $10. Then there is another charge - just under $10 per month per meter if your electricity use (that which you pull of the grid) is below a certain amount - to it all comes to about $30 a month.
What I have read about the new proposed participation charge is that existing solar customers would be grandfathered in for 15 years - i.e., before that charge hit. I am not sure whether the 15 year-period would start from when the new charge is approved or from when a solar customer first installed their solar system. It seemed PG&E was always promoting solar - then they discovered they were losing money because so many customers went solar, and now they want to rethink it all. One argument they are making is that the non-solar customers (and the less affluent customers - because they cannot afford solar) are subsidizing those with solar. This, despite that they previously said "everyone" could afford solar.
   / A newbies DIY solar install #226
I know the power companies "spin" the "facts" to benefit their shareholders, but i question a couple of things. If there was not an abundance of solar, how many new billion dollar plants would they have to build to offset solar or how much would they have to beef up their backbone to handle the increased import from someones billion dollar plant.
The power i produce is most likely absorbed locally with no significant impact on infrastructure.
YMMV
   / A newbies DIY solar install #227
I have solar, but I have to admit that even if I have net-zero to the grid, the grid is definitely providing me with service, and I should have to pay something for that service. Probably not as much as PG&E would like, but even if my solar energy offsets their need for more power plants (thus saving them money), I get something out of the deal as well - they're basically a battery at night (though I'm close to being off-grid-capable for about 2/3 of the year - not winter).
   / A newbies DIY solar install #228
I get that thought process, paying for connection to the grid to provide power when you need it. Especially if you think about the cost of going completely off grid.
   / A newbies DIY solar install #229
Totally agree.
   / A newbies DIY solar install #230
I’ve always said the utilities would balk at grid tie, as they are your battery. With the fees they are starting to charge, makes it not worth being tied. I pay over $20 month to have a landline I seldom use.
2013 FREIGHTLINER CORONADO 122 SD (INOPERABLE) (A58214)
2013 FREIGHTLINER...
Mini Excavator Quick Coupler (A55272)
Mini Excavator...
2006 Godwin GHP45KW-RC45kW Towable Generator (A56857)
2006 Godwin...
Metal Sasquatch (A57454)
Metal Sasquatch...
2015 Wacker Neuson G50 38kW Towable Diesel Generator (A56857)
2015 Wacker Neuson...
Electric Sweeper W/Pressure Washer, Water Hose, & Mister (New/Unused) (A59225)
Electric Sweeper...
