Oil & Fuel A little help with a fuel problem......
/ A little help with a fuel problem......
Patches said:
Good to hear they're on the trail.Fuel cutoff:confused: Mine is manual, I can't see how it could stick closed; another reason to stick with gears and levers rather than solenoids,et.al. You're fortunate to be where you are as we got 8'' of the white stuff Mon. with a foot forecast for tonite into tomorrow:rolleyes:
My pump has the electric selonoid activated by ignition switch, plus a manual lever on top of the unit. I may have been able to get it running breifly by "playing" with the manual lever. The tech told me that it's a shaft with gears on it(maybe bevel & worm setup?, those that've seen the insides might know better) and it is not engaging properly to release fuel to the injectors. It is not the electronics that are screwing up as the selonoid sounds and feels like it's trying to do it's job properly. Appears to be the mechanical internals that are fubared.
We got about six inches in last storm but are just(within 10 miles) missing the Lake Effect dump today. I'm down to the 5hp JD snowblower for awhile. Which works fine for light stuff but when you're used to the convenience of a tractor..................................:)
Highgear said:
So - If it's the fuel -cut off why did it run wide open on you one time ? And if it's just the cut-off why are they replaceing the pump ? I didn't hear the fat lady sing yet !
I don't have a good answer for ya..............
...............I was messing around with the manual lever though.
Probably just easier to replace it as a unit than tear it apart and replace individual pieces. I'll leave that for the techies. I know basically how a desiel works but have no idea what the insides of an injector pump look like. They'll probably send it back for rebuilding maybe? Besides it's being replaced under warranty and sounds like I'll have my machine back in short order. It's all good (or will be when the orange beast is back in my garage).;)
/ A little help with a fuel problem...... #23
Shaft with gears on it, sounds like the rack to me. Doesn't really matter as long as they fix it, but it would be nice to know they have some idea what they are talking about:confused:
/ A little help with a fuel problem...... #24
williekioti said:
Update.............
................ Double your money if you can guess which part went ............
A post in this thread dated 12/24/07: ......also makes me wonder if your shut off solenoid on the pump is energized during no run event and if it is is the plunger opening??
ps....i don't take checks he he he
/ A little help with a fuel problem...... #25
Anyone want to see what I bought with my winnings?:D
IslandTractor said:
Does it have HST and a cab?
OUCH! That's gonna leave a mark..........................
/ A little help with a fuel problem...... #28
Heck yeah, whad'ja get?
/ A little help with a fuel problem...... #30
I hope it was more tractors to sell to great customers from a great dealer.
Steve
/ A little help with a fuel problem...... #31
/ A little help with a fuel problem...... #32
We know Amy got that Rick - what about you?
/ A little help with a fuel problem...... #33
Like John ask, what did you get?
No real man is going to drive anything that COLOR.
Besides, you and I both know neither one of us could get into that thing.
Tom
/ A little help with a fuel problem...... #34
Ok...
I got a case of slim fast :(
/ A little help with a fuel problem...... #35
wallace said:
Ok...
Is that for Breakfast, Lunch or Dinner? :confused: That is about what I would use to wash down my solid victuals. :eek: I hope it works better for you than for me.
/ A little help with a fuel problem...... #36
I think he bought a cot so he could stay in the dealership 24/7/365.
/ A little help with a fuel problem...... #37
No it's a Foo Ton
Come on Island we are in the 21st century...
and a cot wouldn't hold me!
/ A little help with a fuel problem...... #38
Wait a minute........
It's been twelve hours since your 'slimfast' post.
Are you saying the slimfast hasn't worked yet?
Maybe you mistakenly got the 'slimslow'. :eek:
It's a common error. :rolleyes:
Don
/ A little help with a fuel problem...... #39
What is it, a Ferrari?
That is the color of my long gone Saab Sonnet and VW Scirroco.
Mike
Does the flashy green thing at least have a 3pt on the rear?;)
Well, on a positive note the CK is back home as of 1100 am. All is good again. Bring on the snow.................I'm ready to do battle! :)
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
2022 EZ-GO ELITE...
2015 Timpte 40' Hopper Bottom Trailer (A64127)
2015 Timpte 40'...
Coats 5060AX Rim Clamp (A63689)
Coats 5060AX Rim...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
