A little cold water did the trick.
   / A little cold water did the trick. #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I took my end loader off a couple of weeks ago in the morning and by afternoon the sun had heated up the hydraulics enough that I could not connect the hoses back up. I waited a couple of hours for the sun to start to go down and still couldn't hook them up. I took a hose and ran cold water over the cylinders and lines on the end loader and after just a couple of minutes everything hooked up like normal.
   / A little cold water did the trick. #2
I knew there was a reason I always take mine off in the garage. :thumbsup: Nice trick though!
   / A little cold water did the trick. #3
a rag on the end of the qd and a rap from a hammer will work...
   / A little cold water did the trick. #4
Hmmm...good to know!
I tried getting rid of the pressure but couldn't. I think the hose on the end loader side is female and couldn't find a way to relieve the pressure with a screw driver. There is probably a way I just didn't know how.
   / A little cold water did the trick. #7
Some years ago I tried all the release the pressure tricks pushing the end and finally loosened the hose connection with an opened end wrench.
   / A little cold water did the trick. #8
You're correct, it's the female end, but I would not go after that with anything metal. I carry a 4" piece of 1/2" hardwood dowel in the toolbox. I put the dowel in the female end and hit the dowel with the pliers I also carry. That pops the ball loose and relieves the pressure. Cover the fitting with a rag if you have one or you're going to get a handful of hydraulic fluid.
   / A little cold water did the trick. #9
yup. that's farm hand lotion. :)
2018 Heartland Recreations (A55758)
2018 Heartland...
2025 ETNYRE BLACKHAWK RTN55TD3 LOWBOY TRAILER (A51406)
2025 ETNYRE...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
New JMR 66" Skidloader Grapple (A50775)
New JMR 66"...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
