A little cold water did the trick.
   / A little cold water did the trick. #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I took my end loader off a couple of weeks ago in the morning and by afternoon the sun had heated up the hydraulics enough that I could not connect the hoses back up. I waited a couple of hours for the sun to start to go down and still couldn't hook them up. I took a hose and ran cold water over the cylinders and lines on the end loader and after just a couple of minutes everything hooked up like normal.
   / A little cold water did the trick. #2
I knew there was a reason I always take mine off in the garage. :thumbsup: Nice trick though!
   / A little cold water did the trick. #3
a rag on the end of the qd and a rap from a hammer will work...
   / A little cold water did the trick. #4
Hmmm...good to know!
I tried getting rid of the pressure but couldn't. I think the hose on the end loader side is female and couldn't find a way to relieve the pressure with a screw driver. There is probably a way I just didn't know how.
   / A little cold water did the trick. #7
Some years ago I tried all the release the pressure tricks pushing the end and finally loosened the hose connection with an opened end wrench.
   / A little cold water did the trick. #8
You're correct, it's the female end, but I would not go after that with anything metal. I carry a 4" piece of 1/2" hardwood dowel in the toolbox. I put the dowel in the female end and hit the dowel with the pliers I also carry. That pops the ball loose and relieves the pressure. Cover the fitting with a rag if you have one or you're going to get a handful of hydraulic fluid.
   / A little cold water did the trick. #9
yup. that's farm hand lotion. :)
UNUSED FUTURE MINI QUICK ATTACH PLATE (A54757)
UNUSED FUTURE MINI...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
UNUSED FUTURE CW59 - 59" PADFOOT COMPACTION WHEEL (A54757)
UNUSED FUTURE CW59...
UNUSED FUTURE HWG44 - 44" MINI HYD WOOD GRABBER (A54757)
UNUSED FUTURE...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
