Front-End Loader A good reason to check those FEL bolts
   / A good reason to check those FEL bolts #11
I just checked the JD 640 loader mounts on my JD 6415. It has 7 bolts per side. 3 are easy to get to, they were tight, 2 are between the uprights and tractor frame, medium to get to, they took 1/4 to 1/2 turn to make torque spec. The last 2 are inside the mount. There is window cut in the bottom to get to them, limited room to work. I had to jack the front of the tractor up the get clearance to swing my torque wrench (3/4" drive). They took 1/2 to 3/4 turns to get to torque spec. I am glad I checked.
Sellick 560 Forklift (A57148)
Sellick 560...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56435)
2022 John Deere...
2013 JCB 3CX Extendahoe Loader Backhoe (A55973)
2013 JCB 3CX...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
New/Unused 13ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 13ft X...
2017 Komatsu WA500-8 Wheel Loader, S/N A96097, PIN# KMTWA134LGNA96097, Komatsu Turbo Diesel Engine, (A59076)
2017 Komatsu...
