Front-End Loader A good reason to check those FEL bolts
   / A good reason to check those FEL bolts #11
I just checked the JD 640 loader mounts on my JD 6415. It has 7 bolts per side. 3 are easy to get to, they were tight, 2 are between the uprights and tractor frame, medium to get to, they took 1/4 to 1/2 turn to make torque spec. The last 2 are inside the mount. There is window cut in the bottom to get to them, limited room to work. I had to jack the front of the tractor up the get clearance to swing my torque wrench (3/4" drive). They took 1/2 to 3/4 turns to get to torque spec. I am glad I checked.
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A56857)
2007 Godwin Pumps...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
2025 Swict 78in Bucket Skid Steer Attachment (A56857)
2025 Swict 78in...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
60in Forks (A56857)
60in Forks (A56857)
1998 Caterpillar 12H Articulated Motor Grader (A55973)
1998 Caterpillar...
