a few problems with MF 231s
/ a few problems with MF 231s #1
gaswamp
First off my 3 point lift will not lower. Hydralic fluid level looks fine. any ideas
Second prob is sometimes when you turn the key it will not crank. You have to do it about 3 or 4 times before it engages. Is there some kind of safety switch. Light come on it just want turn engine over
/ a few problems with MF 231s #2
I have the same tractor. I had an issue with the key switch turning that caused an issue with starting, also move your transfer shifter to ensure it is hitting neutral.
For the lift, there may be an issue with the draft control. Pull the manual for that one.
T
/ a few problems with MF 231s #3
Just realized this wasn't a recent post. If that tractor hasn't been running by now it is probably burnt.
1/4" Quick Attach Blank Plate (A66408)
1/4" Quick Attach...
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
45K LB LOADING RAMP 25'X101" (A62613)
45K LB LOADING...
2014 International 4300 Single Axle Dump Truck (A62613)
2014 International...
1970 Freehauf Lowboy, 20' Deck with 3' Dovetail (A62679)
1970 Freehauf...
