A few finish mower questions
   / A few finish mower questions #11
Kevin, I like the look of that wheel...where did you find it? TSC had some nice rubber wheels that probably would be an upgrade but they were expensive at over $30 each.
I just did a quick search on google for "mower deck wheel" and looked at the results for the rounded ones. I don't recall how large the OEM PT wheels were, but I'd think you'd want to get a similar diameter to allow of the same amount of height adjustment. Probably doesn't need to be perfect. If you always mow at a certain height, you might be able to go a bit smaller and just move it down the bracket to make up for the size difference.
Might be able to find some cheap on ebay too. Lawn Mower Deck Wheels | eBay
   / A few finish mower questions #12
I was at Boeing surplus and found a pair of casters for $5, made of aluminum with a tire of some kind of plastic. They were rated for 500lb each and have needle bearings with grease fittings. They have lasted very well.
   / A few finish mower questions #14
https://surplus.boeing.com/Index.cfm
I have gotten wheels from TSC. First the price is not great. Second the bearings do not seem to last long. Remember when you get things from TSC they are just like Kmart, Walmart, Lowes, Harbor Freight and Home Depot for some items. They buy stuff by the container from China and mark up as they see fit. You can buy the same stuff on the internet for less money sometimes.
   / A few finish mower questions #15
Well, i was looking up the address on the interwebs and found this address....But also found this "Boeing Surplus Store to close"? I admit, i haven't been there in a few, used to go fairly often. So maybe online only? Maybe next time im going by Kent i might try to stop in and see if it's still open. It's probably the most amazing surplus store i've ever seen.
20651 84th Ave. S.
Kent, WA 98032
Phone: 425-965-4400
Hours: 11 a.m. to 5 p.m. Wednesday - Friday, 9 a.m. to 4 p.m. Saturday
   / A few finish mower questions #16
I got replacement wheels at Grainger.com. large assortment and they have roller bearings. 2 years now and work great.
2011 Ford F150 Ext. Cab Pickup Truck (A55973)
2011 Ford F150...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
Cushman Cart (A55853)
2014 BMW X1 S Drive 28I (A56859)
2014 BMW X1 S...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
